Case Pics
LCB001
Aylmer QC.
It is a Highspeed PC EATX Tech Station which I modded so I could fit the CoolIT Boreas into it.
Is this the new PSU testing station you mentioned over at jG's, I'm looking forward to what you have to say about some of the new PSU's out there...:thumb:
Yamcha
Calgary, AB
My New AMD Dragon PC :p, everything is new except the case, and its really squishy inside, took me hours to get everything as mess free as possible..
SugarJ
Langley, BC
If I recall correctly, those fan leads on the 900 are long enough to run under the mobo. Then you could tuck those molex plugs under the drive cage, and they wouldn't be quite so obvious.
Nice build though.:thumb:
MacJunky
Grande Cache, AB
Put your leg up on a chair or something then use your knee to stabilize the camera. Unless you have a tripod.. in that case use it. :p
jay51
Mission
Mm-u2ufo opti-1203
well here is my latest ,don't mind the wires still thinking of solution to hide them :haha:
cable management in MM. << --- :rofl:
im still going to add a 320 rad cpu/gpu WC loop,but need to try hide the mess of wires first .before adding more,but it's getting there.and i wanted to see what it looked like lit up.
what do you guy's think?
any cable management tips/ideas?
i will be sleeving the wires .
1Tanker
Ontario
***drools*** Sexy!:thumb: Did you choose beige? I'm not used to seeing anything but black anymore...the way it was with beige.:biggrin: Cable-management should be a breeze in that puppy. Some cable-ties, less-than 1/2 hour and your golden.
cwestwell
NWT
I think that is white....not old PC beige....there is someone else drifting around here with an awesome white water cooled UFO.
kyle_L
Port Coquitlam, bc
everyone can shut up about the cables im still working on messing with settings and all that crap. so heres the other white case
and at night. the blue is acctually uv purple thats just how my camera picks it up.
THAT BETTER.
