Case Pics
lowfat
Grande Prairie, AB
Actually it looks alot like my first attempt at sleeving and wire management:doh: But what lowfat said about the heat shrink....it will clean up the ends alot.:thumb:
same here, i used cable ties the first time i sleeved + i used pink sleeve. WOW that thing sure wasn't pretty.
Rhinofart
Member
British Columbia. The Okanagan to be exact.
Pink?
I can't say I have ever hear anyone admit that they used the Pink UV sleaving.:shok: The next case I want to build is going to be an acrylic case. But I am actually going to take the time to hack all the PS wires and make them all exactly the length I want them, sleeve them all acording to what component they go to. Just take my sweet time, and make everything 100000% perfect.
omgwtf
Montreal
My first system build from scratch. Go easy on me... :thumb:
Schwarz
Member
Quebec
Here's my hardcore cooled PD805...
Sadly I think that I will be water cooling soon since that thing is annoying.
Didn't think it would produce so much noise.
On a side note...this is a commando motherboard and I can't run my 2 8800 on it, I took the pic when I tried to use modded drivers.
I should be receiving my striker extreme today or tomorow.
Babrbarossa
New Brunswick
Wow Schwarz- what kind of overclocks are you getting with that thing?
OMGWTF- how did the installation go- everything copasetic?
Schwarz
Member
Quebec
I'm only at 4Ghz on my PD805.
Its really hard to get it stable after that.
I can get it to 4.1 but then its not stable at all.
Its a Mach II GT.
You can get one from kitronics.com here in Quebec.
As far as install I had to cut a hole at the bottom of my Lian-li which wasn't hard with a metal saw.
And as far as installing its not really that hard you just put the bracket with some kinda sealant, put some on the head of the hose and you are now airtight.
sswilson
Moncton NB
How does that setup manage condensation? What kind of temps are you getting out of the cpu?
Patriote
New-Brunswick
Thats freaking awesome Schwarz! Thanks for the link to kitronics.com! Always wanted to try Phase change on a C2D.
Nice first build there "omgwtf"!
omgwtf
Montreal
Thanks guys..I've got a pair of 2X1GB Ocz Pc2-6400 800 Mhz.. When I power up the system I got 1 long beep and after 2 short..
