Case Pics
r0k0
Age
31
Gatineau, Quebec
yeah at the end near the motherboard, would be plenty of room on my GTX 560 its sitting rear card closest to side panel, my 5970 sitting on the side panel completly , if they would stick them on the rear side of card closest to mobo would be alot better
clshades
Calgary
You seriously limit your market putting the power connectors on the end of the card as it makes the card 1-2 inches longer. Anyone with a smaller case simply can't buy the card. I reckon the power connectors themselves need work.
Silent_Avenger
Toronto
I haven't been here long but I guess I'll post my case pics anyways. Be gentle :haha:
My main system not a powerhouse by all means but it has served me well for the last 2yrs and it does handle all the multi tasking I do. Also sorry if some(if not all) the pics are a little blurry I use a crappy point and shoot which sucks in low light.
AMD Phenom II x4 955 C2 Stepping @3.6Ghz 1.38v
MSI 970A-G45 motherboard
16GB Patriot Sector 5 DDR3 1333mhz 9-9-9-24
XFX Radeon HD4890 900mhz core, 1050mhz mem
Win 7 Ultimate 64-bit
Corsair TX650W(as if you couldn't tell from the pic)
300GB WD Caviar Black (main drive) 250GB WD Caviar Black (PVR drive) 1.5TB WD Caviar Green (Data Storage/backup)
Corsair H100
CM Cosmos S case
Let me know if you want to know anything else.
Yes that temp is fairly correct(I never really trust these fan controllers) it's reading the temp on my 4890 which at the time was running [email protected] usually while gaming it never gets above 75C
My attempt at trying to take a pic of the interior glow effect.
My awesome cable management behind the mobo tray :whistle: might have been cleaner if I had a modular psu.
Next is my dedicated folding pc also not a powerhouse but it still manages a good 6700ppd on a stock Pentium D 820 and a GTS 250 sadly it doesn't fold for HWC but I've started my main rig on that :biggrin:. The case, mobo, cpu are all from a HP Media Centre m7160n
And Just for fun the case on my 360 that I did in highschool so it's been through a bit going to friend's houses and lan parties and such.
Silent_Avenger
Toronto
your GTS 250 is a Zotac right ? :p
Yuppers and has a lifetime warranty apparently. Couldn't pass up the deal at NCIX $40 with MIR. The rest of the system is pretty much all hand me downs from family members or freebies from friends except the V8 which came from my main system(which I was surprised fit in the case). Then spent about $15 on paint and masking tape cuz I didn't have any around.
Silent_Avenger
Toronto
Yea I pretty much had no option other than to open up the side more just because of the heat from the GTS 250 and the lack of airflow if I kept the case stock. The temps were 90C with 82% auto fan when I was testing at stock speeds now it's running 70C OC'd. I actually found that mesh in a field behind my parent's place long time ago when I was a kid brought it home and it sat in the garage since then. The cool thing about it is that the rust pitted the metal giving it a nice texture. I also used the same mesh on the rear exhaust fan in white held on with bent ends.
Birk
Burlington, On
I did a little clean up in my case. Did some seriously ghetto cable managment (Electrical tape anyone?) It's still not complete as I'm expecting to get this thing Watercooled in the next 2 weeks or so.
kyle_L
Port Coquitlam, bc
cleaned up my computer today, just need to cut a window into the side panel now. i wish i could add another 6970 but my empty wallet wont let me.
