Number 3 in my sig. As soon as I find a good CPU clock, it will be a 24/7 folder too.That's just baller for a server rig.
Specs?
Specs?
Jesus Lowfat I just looked at your specs 46TB of data, Nice Man, now that is storage.:thumb:Number 3 in my sig. As soon as I find a good CPU clock, it will be a 24/7 folder too.
You should have a look at my pcx2000 only one way to route since clearance behind the MB is 1-2mm, is down the rear front, ie : deep front. It is back a few pages but still one hell of a clean build.Silent Avenger... the Coolermaster Stacker 830 was probably the worst lol
http://www.hardwarecanucks.com/forum/548558-post1649.html
Oh yea I forgot about that case. You think it wouldn't have hurt for CM to add an extra cm or two behind the mobo tray. Not like it's really gonna matter for a full tower case anyways.Silent Avenger... the Coolermaster Stacker 830 was probably the worst lol
If you can what I would do with those satas is get them at the right bend coming off the mobo all laying flat against each other and then either sleeve it split loom it or just plainzipties. You can add the rest of those wire or most of them to to the "bundle. Just kept it clean and symmetrical/not all twisted up and it would look sharp even ziped. Just IMo and maybe you didnt see it.IDK I still see a jumble of wires at the top of the case there. :haha: j/k That's a really clean build.
I do see what you mean however I don't want to bother sleeving a non modular power supply it's just not worth it. Probably would have had a little better cable management with a fully modular PSU though and proper length SATA cables. :blarg: Maybe someday.
Like I said I would need proper length sata cables since the ones I have are a little short and don't allow for proper cable management(gotta work with what I have) also getting right angle sata cables wouldn't work either because the cable would be pointing up instead of down on this board(really stupid design by MSI).If you can what I would do with those satas is get them at the right bend coming off the mobo all laying flat against each other and then either sleeve it split loom it or just plainzipties. You can add the rest of those wire or most of them to to the "bundle. Just kept it clean and symmetrical/not all twisted up and it would look sharp even ziped. Just IMo and maybe you didnt see it.
You should see what you cant, a shit ton of spare cable is stuffed up in the odd bays along with Satas/molex and fan wires. but almost all the sata/molex/powerfans/ect I/O run down that back little corner on way to go from chamber to chamber, PITA.
