Case Pics
slippy
Toronto
Got some sleeved cable extensions.
Man, it's starting to get tough hiding all these cables in my small case.
Still need to find a place to hide a SSD. Do they make 5.25" brackets?
Silent_Avenger
Toronto
You could get some 5.25" to 3.5" brackets then some 3.5" to 2.5" brackets onto those. Or just buy some sticky Velcro tape and put it wherever you want. :thumb:
slippy
Toronto
^ Are you just using the stock CPU heatsink?
Yes, I haven't even overclocked. It's a X3 man lol
slide ur SSD right on the motherboard tray under ur motherboard and above ur PSU.
You mean with tape? See below. Plus, I wouldn't want to have SATA and power cables over there.
Does this last? I'm worried about the longevity of such a solution (heat?).
