Case Pics
DurkaDurka
Toronto area.
You are the first person I've seen with that HSF actually in a system.
It works pretty good, my cpu idle is around 24 (core temp) degrees, highest load temp was around 48 (core temp) degrees with Orothos running for about 10 min. I ripped the stock fan off of it because it didn't push a whole lot of air and replaced it with a higher output one I had laying around. So far, so good.
enaberif
Calgahree, AB
Fans on the wrong way tho :p Should move the air from the front out the rear :ph34r:
DurkaDurka
Toronto area.
I have the fan set to pull the air inwards and exits via the 120 fan on the top of the case. If I had put the 120 on the side facing the 120 on the back of my pc, the cooling effect would have been rather redundant.
dosmond
Ol' Athlon xp 3200+
Here's a few shots of my old rig (New parts for pc are in the mail!)
AMD Athlon 3200+, Gigabyte GA-7VT600-L, 768Mb PC3200 Memory,
ATI Radeon X800GTO with 16 pipes mod, no name case...
New rig will be
[FONT=&quot]Antec Sonata III Case w/ 500W Earthwatts PSU, Intel Core 2 Duo E6600 Dual Core [/FONT]
[FONT=&quot]Gigabyte GA-965P-S3 LGA775-P965, Seagate Barracuda ST3320620AS 320Gb - 7200rpm SATA II[/FONT][FONT=&quot] [/FONT][FONT=&quot][/FONT]
[FONT=&quot]ASUS Radeon X1950 Pro, Patriot Signature Line 2GB PC2-6400 Dual Channel[/FONT]
will post new pics when my pc build is done!
[FONT=&quot][/FONT]
3.0charlie
Bedford QC
No-name case? Actually, that's a Raidmax Scorpio. Had a couple' years ago, very similar. The side panel and exhaust gives it away.
Enjoy the new rig - it will be a world of difference!
John
Patriote
New-Brunswick
Awesome new pics of my system. Just took them :biggrin:
Thats with new 8800GTX (Big Thanks goes to Dynasty :thumb:) installed and some more cable management done. Also, i removed that crappy mosfet Asus include with their motherboard...It would not make any temps difference and the NB would become enough hot that i couldn't touch it for more than 5 secs. Instead, i removed the Asus "shield" and hooked my Sunon 60mm fan. NB is pretty much just warm now.
PS: I know... I know... In the first pic you can actually see some of my toes right next to my phone. :haha: Go figure why it's on the floor :doh:
Patriote
New-Brunswick
That's a helluva lot of cooling for just the CPU- got a GPU block coming?
Yeah i have a DD NV-88GTX block but im afraid it'll suck ... You should have seen the internet design when i opened the block to clean it ... And hooking back the tiny o-ring to re-mount back the top of the block was such a pain in the *ss...
I might try to get a EK or hook one of my multiple MCW60s with maybe a Unisink. But i am real busy these days. I have to move 2 person + me so .. Gotta pack lots of boxes and move lots of stuff around. Wouldn't be the right time to re-do my watercooling build.
dosmond
New PC
Well my new pc is now put together, Here's the specs...
[FONT=&quot]Gigabyte GA-965P-S3[/FONT]
[FONT=&quot]Seagate Barracuda ST3320620AS 320Gb - 7200rpm SATA II[/FONT]
[FONT=&quot]ASUS Radeon X1950 Pro[/FONT]
[FONT=&quot]Patriot Signature Line 2GB PC2-6400 Dual Channel[/FONT]
Of course I am reusing my Samsung 940bw [email protected] widescreen LCD, my mouse, keyboard and a liteon SOHW-1693S 16x dvd burner....
One thing I have to say my cpu temps are way lower then I expected, maybe 43 degree's celcius running 3dmark 2006, and thats with only the one stock antec 120mm fan, and stock cooler, the only thing I can say that really gets hot is the intel chipset... I can't keep my finger on it, is that normal for a 965 chipset?
