3.0charlie
The Gigabyte Aurora has a door too. Like others have said, you can't go wrong with Lian Li (PC-65B) and I personally like Silverstone very much - the TJ04-B would be a good choice for you.
John
John
Yeah, the thing that covers the optical drives, power button, etc. ... I hate doors ...
The Aurora is too big and has a door, so it's out ...
The Lian Li PC-G50B doesn't have any 3.5" bays, but the 5.25" USB bay is an option. I also need to fit a card reader in there, too. Do you know of any black 5.25" card readers w/ 2+ USB ports ?
I found one by Startech w/ 1 USB port ...
This is the one I've got in my case.....
http://www.enermaxusa.com/catalog/p...id=53&osCsid=e1b5b1eec647273e3cad1db824d17eff
You might have to look around a bit to find it, but I'm sure there are other fan controllers out there with everything you're looking for.
I couldn't find an Enermax one in black, but I found this which looks to do the same thing ...This is the one I've got in my case.....
There is no 3.5" bay in the Lian Li that I'm looking at ...There's also this if you want it in a 3.5 bay instead. No card reader though.
