Case with best air flow?
Quirck
Member
My budget is around $100-$125
I've been looking at coolermaster CM 690 II Advanced and HAF 922,
Is there anything better?
_dangtx_
mtl
or you could look at the 912. unless youre packing a few gtx 590's and dual socket mobo you should have some coin left in thine pocket
and still decent airflow :)
manoy385
Member
Richmond, BC
If you don't mind the looks, get the Silverstone Raven RV03. Same cooling performance as the FT02 and RV02 which are widely regarded as pretty much the best air cooling cases. The RV03 has slightly worse HDD cooling performance compared to its predecessors if you put your hard drives behind the motherboard tray but it costs significantly less and is also smaller.
Silverstone RV03B-W Raven 3 Black ATX Gaming Case 7X5.25 4X3.5INT 2X2.5INT No PS - DirectCanada
ASPM/PM @ NCIX or Memory Express to get it even lower.
BrutalGreen
Québec, Canada
2nded also if u can find a good deal once in a while the rv02 does go for about 130$ which would be better but not always available
sixthsense
New member
I really like the design of the coolermaster and lancool cases. The only issue I see with Coolermaster cases are the lack of stock fans (which are not even great by any means to start with) RV02 is a good case, but it does have it's flaws (which I stated in another thread). Xigmatek Utgard is another good case for the money, but doesn't have front facing hard drive bays (which is a pet peeve of mine)
