Changing USB Polling Rate to 1000hz (or lower)
Unknownm
New Westminster, B.C
If your like me and hate default 125hz that all windows install (Unless you modify) here is a quick way to change your USB polling rate to 1000hz (1.00ms response time).
Note: Some mouses don't go all the way up to 1000hz. This is mainly in wireless mouses
Windows Vista & 7 64-bit
1. What you need: HIDUSBF.zip - dimr.exe (Direct Input Mouse Rate)
2. Extract HIDUSBF.zip & dimr.exe into a folder
3. Right click on "HIDUSBF.INF" find install (If Warning comes up about unsigned drivers don't worry)
4. Open up dseo13b.exe and check "Enable Test Mode"
5. Reboot
6. After Reboot you will see "Test mode Windows XXXX build XXXX" You can get rid of this but for now reopen dseo13b.exe and check "Sign a system file"
7. In the box type in "C:\Windows\System32\Drivers\HIDUSBF.sys". If correct a window will come up saying "The system file has been signed succesfully..."
8. Reboot
9. Reopen HIDUSBF folder and click on "Setup.exe"
10. Find your mouse click on it (it should be highlighted has blue) and at the bottom of the window check "Filter On Device" and select your Rate
11. Click Restart and open up dimr.exe. If it's still runs default 125hz reboot your windows Vista or 7 64-bit operating system again
12. To remove watermark open dseo13b.exe and click on Remove watermarks. It will link you to the website with the correct files to remove it
Windows XP/Vista/7 32-bit
1. Right click on "HIDUSBF.INF" find install
(Note sometimes with XP if you apply and the mouse stops responding in this case restart again and try again)
2. Open HIDUSBF folder and click on "Setup.exe"
3. Find your mouse click on it (it should be highlighted has blue) and at the bottom of the window check "Filter On Device" and select your Rate
4. Click Restart and open up dimr.exe. If it's still runs default 125hz reboot
