Cheap new box
perfecto
Active member
Surrey, BC, Canada
... I don't really plan on doing much in the way of "hardcore gaming" but I'd like a system that can actually keep up. I'm not really interested in non-Intel processors, and am not really interested in going ATI again either.
If the system can do it reliably, I may consider overclocking it. I'm also going to add another 2g of RAM in the near future.
How does this look in terms of a "bargain" build which still has some decent performance?
1 x Intel Core 2 Duo E7200 Dual Core Processor LGA775 2.53GHZ 1066FSB 3MB Retail Box
1 x Arctic Cooling Freezer 7 Pro LGA775 2500RPM 45CFM
1 x Gigabyte EP45-DS3L ATX LGA775 P45 DDR2 PCI-E 2PCI SATA2 HD Sound 2GBLAN Motherboard
1 x OCZ Gold XTC PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-15 240PIN DIMM Dual Channel Memory Kit
1 x BFG GeForce 9600GT OC 675MHZ 512MB 1.8GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card
1 x Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio
1 x Corsair VX450 450W ATX 12V 33A 24PIN ATX Power Supply Active PFC 120MM Fan
1 x Seagate Barracuda 7200.11 3.5IN 500GB SATA2 8.5MS 7200RPM 32MB Cache NCQ Hard Drive
1 x Samsung SH-S223F Black SATA DVD+RW 22X8X16 DVD-RW 22X6X16 16X/12X DL INT DVD Writer OEM
SugarJ
Folding Team
Langley, BC
That system will do just fine on a 19" monitor. If you have a bigger LCD, you may want to upgrade your GPU a bit.
perfecto
Active member
Surrey, BC, Canada
Yeah - for 119$ CDN that BFG card is a pretty good bargain... can you suggest anything comparable or better in that price range? :)
Kayen
Edmonton
evga at futureshop for 99.99
that is the 9600gt
EVGA 8800GT, the 8800GT gives better performance than the 9600GT, and not sure that the factory overclock is large enough to make a significant difference to change that.
Kayen
Edmonton
Do you plan to order or do local pick up at a store?
Cause you might want to call in and check, that was the case with my 9800GTX+, they had one left luckily for me :).
