Theblackmages
Well I just started my project about doing a side window for my case, It can be a little guide if you want too.
Today I just cut the rectangular hole on the side.
Tools I used :
-800rpm electric drill paired up with a cut off wheel
-Dremel to make the cuts straighter
the reason I used a cut off wheel was because it's faster than using a dremel and the drill is stronger.I also had no cut off wheels for my dremel so...
First of all : you really want to measure twice before you cut because you really don't want to not cut right.
I used a pencil and a ruler to draw my lines on the other side,I then put masking tape over it so it would be easier to follow the lines when cutting.
I did not protect the paint on it because I was going to repaint it anyway, you could be extra carefull, but trust me on this one it's hard not to scratch it.
on the next pic you can see that its scratched at some places, I will repaint the sidepanel this week. the bottom is a bit wavy, I might trim it a bit again.
It doesn't have to be perfect, I will add some chrome trim around it.
stay tuned for updates, I still have a lot to do :
-repaint the side panel
-put a chromed trim
-put a plexiglass and do a 92mm or 120mm hole for a fan
further mods will be :
-cuts for better wire managemnt
-polish the top of the AC freezer 7 pro
-paint the inside of a case
Tools I used :
-put a chromed trim
