Sheep
Greetings,
I've been a fan of this site's reviews for quite some time, and recently purchased a new computer for a HTPC/gaming setup. The hardware is as follows.
-Gigabyte EP45-UD3L
-Sapphire Radeon HD4870 512 GDDR5
-WD 1 TB Black
-G Skill PC2-6400 2x2gig
-Thermalright AXP-140 with Noctua NF-P12
-Corsair HX620
-Intel Core2Duo E7400
-Old LG DVD rom (IDE)
-Silverstone Lascala LC-13B
My problem lies with cold boots. I usually shut my computer off at night before bed (actually always, stopped now that this problem has occurred), and restart it after I get back from work the next day. At first I was running Windows Vista, but didn't like it. I was also running the stock heatsink, and wanted to upgrade to the Thermalright AXP140 (More of a want then a need). After installing the heatsink and reformatting back to XP Pro, I have been experiencing cold boot freezing. It usually takes 3 restarts before the computer operates properly (First start freezes once windows loads, second start freezes at the Mobo logo screen). Also, my computer is currently not recognizing my IDE DVD rom. Before, it was recognizing 2 WD HDDs when I only have 1 (this problem is no longer present).
I purchased this computer from NCIX, and assembled it myself with the help of some more experienced friends. I am not skilled with computer assembly, and did not install the heatsink myself. I do however have google, and looked up how to do it. From what I can tell, my friend put on WAY to much TIM. The AXP-140 uses a back plate and I figured the extra TIM (Thermalright supplied TIM) would push out of the way to the sides. My temps at Idle are around 37*C, which I believe is the norm for a HTPC case with poorer airflow.
Basically, before I resort to standing in a lineup at NCIX on a Saturday to have them check for defective hardware, is there anything you can recommend that would help? I know I need to replace the DVD-Rom with a DVD Burner, and will pick up a SATA one when I do (which would be when I take the computer back), but other then that, myself and my friends are stumped as to the cause of this problem.
Thanks for all your help,
Sheep
-Gigabyte EP45-UD3L
-WD 1 TB Black
-Corsair HX620
Sheep
