Comment Thread for GTX 480 and GTX 470 Reviews
Arinoth
Halifax
If i had the spare time and well equipment resources i could probably attempt to rig something up that would allow you to directly measure the power used by the cards rather then the entire system since all you would need to do is somehow be able to measure the voltage drop or current use off of the power rails to the card (as well as the resistance if one can only measure the voltage or current usage) and then run it through through ohms law to give you the effective power usage
CMetaphor
Quadfather
Montreal, Canada
If anyone knows their electrical engineering well enough to build us something to measure direct power from the cards, let me know.
Why not just modify a pcie riser card and increase the height of the retention bracket for that slot on your test bed? :thumb:
martin_metal_88
Quebec City
But if the card is getting that hot that loud and have a such high TDP...is she really interesting in folding??? personnaly I think no.
Not sure what to think of this:
AnandTech: NVIDIA?s GeForce GTX 480 and GTX 470: 6 Months Late, Was It Worth the Wait?
Anandtech says that the 480 will deliver 3.5X the performance of a 285...thats 25-30K easy, a small difference from the ~15K Legit Reviews. They use this graph to determine the 3.5x number:
Never saw 'nodes per day' before, but food for thought for the folders. To be clear, I seriously doubt 3.5x performance.....
_dangtx_
mtl
pops an electrical engineer..not sure how much time hes got in his hands tough.
or....how about using a mobo with onboard graphics. take the desktop reading while on onboard , then drop the card in and take another reading, then load [email protected] or furmark on it and see what gives difference wise at the socket or where you check it(at the ups?).
SKYMTL
HardwareCanuck Review Editor
Montreal
A PCI-E riser still allows power to be pulled through it. It is very easy to measure the power from the PSU by the use of a clamp meter but how do you measure the power going through the riser card?
CMetaphor
Quadfather
Montreal, Canada
Break the traces in between the ends of the riser perhaps? its only two-sided (not multi-layered) so it is possible.
_dangtx_
mtl
forget about the riser card. use onboard for desktop display, then drop the whatever card in and check again. easy way out.
SKYMTL
Montreal
The CPU, memory, HDD, etc. will influence the outcome. The whole point behind the exercise would be to isolate the GPU's power signature.
Arinoth
Halifax
As i'd mentioned in my PM to you, if i knew the electrical characteristics of what a 6-pin and 8-pin connectors are suppose to deliver (ideal) i could figure out a circuit/connection method to hook up multimeters and use Ohms law to find out the power consumption
_dangtx_
mtl
ok like dropping the video card in a machine specially made for that, like a memory tester for rams?
