Computer freezes on startup
Airw4ves
Active member
Red Deer, AB
So basically, I start the comp up and after logging in I am presented with a "Ideazon Z Engine has stopped working" window. I click Debug The Problem, and I immediately get (Not Responding) and the comp is completely frozen. After restarting I try "Check Online for solution" and "close program, both with the same results. If I try and open up anything else it also freezes. I'm not sure as to what the problem would be.
Any ideas would be greatly appreciated.
Thanks!
ZZLEE
KANATA
How old is the boot drive.
try toool to check boot drive fore errors.
Supergrover
Okanagan Falls, British Columbia
Thanks!
Uninstall Z-Engine software
Start the computer, load windows, open task manager, kill Zengine process, uninstall zengine software , reboot.
Airw4ves
Active member
Red Deer, AB
Tried to open task master and the thing freezes again and I am forced to restart. Tried to restore and now I'm left with a black screen after initial windows symbol flash.
I've tried Safe Mode and get the same thing.
Go into boot manager and select my boot disc and it says BOOTMGR is missing, how do I go about fixing this?
Airw4ves
Active member
Red Deer, AB
Won't let me get into safe mode, all I have is a black screen with my cursor after starting up the comp. I have attempted to repair with OS Disc but didn't do anything. I'm going to keep trying repairing to see if it will fix something.
dandelioneater
Kelowna, BC
Do you have any files that you really need to keep on your OS drive? This is kind of a last resort, but It might be time for a new drive & fresh windows install. This might be the perfect opportunity for an ssd upgrade:thumb:
Airw4ves
Active member
Red Deer, AB
Progress - Now I can log in but I'm stuck with a Welcome sign and glowing wheel.
As for the drive, haven't updated my sig but its on my 60GB SSD
