Computer freezes on startup
Painbringer71
So have you tried a differant standard keyboard? Then repair the OS ( I found this below on Frequently Asked Questions - What should I do if I get the error: "Z Engine has stopped working"? )
This error is caused by a conflict between Microsoft .NET Framework 3.5 SP1 and the previous version of the Z Engine.
You can resolve this issue by updating to the latest Z Engine. Here is how:
Make sure you have administrative rights to your computer. Please make sure your device is connected during these steps. Please try the following to see if it helps (WARNING: this will delete your Custom Mods):
- Uninstall the Z Engine software by going to Start->Settings->Control Panel->Add remove Programs
- Reboot computer
- Delete the following folders (WARNING: this will delete your Custom Mods):
1) C:\Program Files\Ideazon\Z Engine\
2)
a) If you have Windows 2000 or XP:
Click Start->Run and type “%appdata%" then click "Ok"
Find the Ideazon folder and find the Z Engine folder. Delete the Z Engine folder
b) If you are using Windows Vista:
Start Menu -> All Programs -> Accessories -> Run)
- Re-install the latest Z Engine drivers: www.steelseries.com/downloads
You should have a green Z Engine icon on your system tray which means your device should work properly.
