Computer Loading Error [Important]
MastaChief11
Member
Today I booted up my computer to find that some programs didn't want to open or load. Usually, XFast USB loads at start but when I log in, it is stuck at a certain spot. Google Chrome won't open either, I just a a loading circle for 2 seconds and then it stops. Malwarebytes will occasionally pop up with this error: "[OpenEvent] Failed to perform desired action. Error Code: 2". I did an avast virus scan, but that didn't detect anything. Malwarebytes didn't open, so I did a System Restore to a few days ago, but that didn't help either. If you need my computer specs, I could give them to you, but I'm not sure that would help. Rebooting my computer didn't do a thing, I still have the same issues. Help is greatly appreciated.
NyteOwl
Nova Scotia
Make sure all cards, memory and cables are properly seated. Then next question: what did you install or update/upgrade recently?
sswilson
Moncton NB
If malwarebytes won't run, and browsers won't open, more than likely you've got a virus. You can do the research to find a tool which will attempt to fix it under safe mode (or better yet a stand-alone bootable iso), pick a much older restore point, do a complete fresh install, or pay somebody to clean it up for you. That's about all that will work at this point.
MastaChief11
Member
I haven't installed or upgraded anything recently. Last night, I was using my computer and it worked fine, but this morning it's been having issues.
rfglass
Port Elgin Grey/Bruce
I have had some luck running Mbam in safe mode in infected pc's but 50/50 chance it will run,but if it does it should get rid of any nasty virus
Shadowmeph
I would just uninstall malwarebytes then reinstall it that is what I did way back when it wouldn't run. actually there is a link a couple of posts above you should check out.
