Computer Loading Error [Important]
Shadowmeph
is all of your software up to date with the security, like flash . also do you recognize all of your running processes?
And also did you reboot right after you uninstalled malwarebytes?
MastaChief11
Member
My security software is up to date. I did restart after I installed Malwarebytes. Currently, I am checking my processes to make sure that they aren't viruses.​
Shadowmeph
I am not saying security software I am asking if your software has security updates , I have a program that I run about once every two weeks called secunia which identifies vulnerabilities in non-Microsoft software. a friend of mine told me about this after I had caught some malware just from visiting a website which I had thought was legit I didn't click on anything on the site I was just reading, After I shut down my PC and rebooted the next day nothing worked properly I mean that none of the .exes worked at all and also malwarebytes also stopped working.
try this uninstall malwarebytes, reboot, download/run run this http://www.malwarebytes.org/mbam-clean.exe then reboot and reinstall
now if for some reason that doesn't work out [SOLVED] Fix Malwarebytes' Anti-Malware Error Code 2 - [open event] failed to perform desired action [openevent]
