Computer not sending post signal motherboard reads FF
Shadow_T11
New member
My system had been running completely fine until today when it just would not boot. Fans and water cooling system would run, case lit up, and displayed temps. There is no video out either. I have read around and not found anything helpful. I have had this problem in the past with this system and the 8pin power cable had started to slide out. I ensured it was in and tested it with no luck. Any advice?
Specs:
MoBo: XFX 780i SLI
CPU: Intel Duo 2 Quad Q6600
Graphics: EVGA Geforce 550 ti
PSU: (Not completely sure the brand but I manually tested it already) 850W
Ram: 2 packs of G.skill f2-8500cl5d-4gbpk ddr2
HDD: Seagate Barracuda 1tb
Case: (not sure if it matters) NZXT Guardian 921 b
enaberif
Calgahree, AB
FF.. 780i .. Dead board :
Best pull it all out and test run it on a cardboard box but being a 780i chipset gonna say not gonna look good.
SugarJ
Folding Team
Langley, BC
Unfortunately the nVidia chipset mobos were infamous for burning up. I've had a couple boards with the FF boot code, they were both fried.
howpet
Peterborough On
Been a while since my 680, could have sworn it was a C-something error. Great O/C'er but short lived though.
Do a bit of investigating, all might not be lost. You may have "Lifetime Warranty". If you do its quite likely XFX will upgrade you to a newer chipset....does XFX even offer mobo's anymore???.
If not and a rma is approved then a gpu may be offered. Might be worthwhile looking into. Oh!! and lifetime means lifetime. Whatever they send you back still retains the original warranty.
Shadow_T11
New member
Yeah I would check with xfx, but they no longer do mobos. I am asking for an rma. Let's hope for the best!
