Computer post then reboots
GrumpyGeek
Nova Scotia
Hello HWC..
I have removed everything but the CPU, motherboard and PSU. I have tired another PSU and it did the samething. Now it has to be the CPU or motherboard. I am just wondering if like reseating the CPU would do anything or is one of them fired.
thanks
GG
SugarJ
Langley, BC
Yes, I'd try reseating the CPU. One stick of memory only? Cleared the CMOS with the power disconnected?
GrumpyGeek
Nova Scotia
I had no RAM in it at all.. i cleared the CMOS and i reseated the CPU but nothing. Is there anyway to tell if its the CPU or the motherboard?
SugarJ
Langley, BC
It posts without memory in it? I didn't think you could do that.
And no, there's no easy way to tell if it's CPU or mobo.
SKYMTL
HardwareCanuck Review Editor
Montreal
You need memory for it to POST.
Can you give some system specs?
MARSTG
Montreal
Not to hijack the thread but I have a similar issue : I have a Lenovo SFF system with a Pentium D, and it stays on fine if in BIOS for hours at a time, but when launching windows 7 it shuts down in 2 mins max. Only one stick of ram, HDD, integrated video.
sincity
Active member
Montreal, my city of sin ;)
You can't tell when its either cpu or board unless you have spare of either to try. It's a pita at that point!
Although I did have a bad cpu before and I could tell from a message at post, but it depends on the mobo/cpu issue!
