Computer restarts 3 times after first boot
bliz
Hey , i have a problem and i'm not sure what it is, this morning ,when i started my computer, it started, got the bios screen then it just shut down and restarted again, automatically,and this 3 times, before it booted normally.
Running on a new samsung 840EVO, 1 month old and never had problems with it. Gigabyte cold start bugs?
Crystal disk info says the SSD is ok... also Samsung magician wants me to do a firmware update, could be that?
Thanks
KaptCrunch
Ontario
sounds if a MS OS update was performed
check your Installed Updates
Control Panel\System and Security\Windows Update\Installed Updates
bliz
Could be... Last one was yesterday ( but not an OS update) but i never had these kinds of restarts just after the bios screen, anyway i guess i'll see if it happens again...
Thanks for your answer!
sswilson
Moncton NB
Is this system oc'd? Sounds to me like the bios is trying to find working men settings. If it's oc'd, then try at stock settings, if not, then maybe your motherboard battery might need replacing.
bliz
My CPU is not overclockable ,i only have a light OC on the GPU. I will check the battery, thanks.
ZZLEE
KANATA
How is your back up off your computer. ??
back up your whole computer if you can in case the firmware update does not work out fore the best.
USB 3 and a few tarabites ??
bliz
Well i didn't know that the firmware update was a risky thing ^^ It worked perfectly and now my computer boots fine, if it happens again i will change the battery.
ZZLEE
KANATA
Glad to hear things are good. :)
A back up gives you more peace of mind in case things happen. Prepare fore bad things when they don't happen Be Happy.
sswilson
Moncton NB
Heh.... firmware updates will make bricks out of things just as easily as a bios update.... rule of thumb is to never update bios / firmware on a possibly unstable system except as a last resort.
