Computer shutting down
yycraven
SK
Well My son's computer is shutting down on it's own.
for specs its a 775 3.0GHz with Asus mobo
older nvidia card. My son does not play any hardcore games.
So I turn the system on and with in 10mins it shuts off on its own.
I am thinking its PSU its a 450W. Have own this system for a few yrs.
Maybe its overheating, fans are running, there is no dust in the system as I keep them clean.
Anyone have any idea's
yycraven
SK
Arrr, RIP EVGA NF41:thumb:
Check temps also, if you have a multimeter you can check the volts. Swap in another psu if you have one handy.
Is it actually Shutting down or "hard" off?
Well this is weird, okay so I left the pc on, went to pick kids up from school came back still was on. So thought I had figured it out it being heating problem as I open case right up.
So then I started to play just a online game nothing to stressful just one of the games my son plays online
when he started playing it shut off
not a real hard off, but yea shut right off screen goes blank and pc is off.
might have to go buy a 450w psu tomorrow just for back up
Photograph
T.O.
I'd also run a memory test to see if there is a bad DIMM in there somewhere, sounds like a similar issue I had with my HTPC that turned out to be some OCZ memory that died.
yycraven
SK
Thanks guys will try that out. It seems maybe to be Ram or Card, If i leave pc running with out any thing going on like games, or video. It is fine, but once I put some sort of load on it shuts off.
Will test card then ram.
yycraven
SK
Well I put my spare ATI X600 card in his case and system shut down, took out the ram and put in a 512 DDR2 stick in one Dimm at a time and system still shut down.
looks like I will have to go buy a PSU and try that out next
since I have no spare PSU.
I looked all over the Asus board and could not see any blown Caps.
So I am hoping its the PSU. My son is not to happy about this.:sad:
Here is a Question can ATI drivers shut down the system
like I mean just shut the system off.
Looks like I found the problem
The cooler master hyper 110 HSF one of the fasteners let go and is out of its leg. looks like I will need to replace it.
