DeveloperRedneck
New member
- Joined
- Feb 19, 2025
- Messages
- 2
I'm currently using the XPG Valor Air with four black (non-RGB) fans.
I found the Asus A21 case without fans for 1000₺ ($27.5 on the used market but this case is bought 1 month ago and he said he never used before bcs he bought ATX case while case only supports mATX.
I believe I can sell my Valor Air for 1000-1200₺ with fans or 500-600₺ without fans.
If I sell my Valor Air without fans for 600₺, buy the Asus A21, and reuse my four non-RGB Valor Air fans (XPG Vento 120, non-Pro), the total cost would be 400₺ ($11).
If I sell my Valor Air with fans for 1200₺, buy the Asus A21, and also purchase 2x P14 Max and 1x P12 Max white, the additional cost would be 1500₺, making the total cost 1300₺ ($36).
If I sell my Valor Air with fans for 1200₺, buy the Asus A21, and purchase 3x TL-C12B-S V3 (3-pack) for 800₺ plus one extra for 350₺, the additional cost would be 1150₺, making the total cost 950₺ ($26).
Which option do you recommend? The reason I want to change cases is that while the XPG Valor Air provides good temperatures, it only supports GPUs up to 305mm, which limits my upgrade options.
