Cooler for EVGA 680i SLI...and NCIX question
dheian
Member
Working on ordering my first build since the mid-1980s...
Thinking of ordering the EVGA 680i SLI mobo to go along with an 8800GTX, an E6600 slapped in a TJ09 case with a BenQ 24" monitor.
a) Any strong reasons not to and if so, what recommendations for comparably priced mobos?
b) I thought I read in one of the reviews that some CPU coolers are a tight fit on the EVGA...any suggestions for a good one that does fit?
Also, probably ordering from NCIX. Is it true that they don't charge Ontario PST?
Thanks.:bananafunky:
Magice
Member
From what I've heard that motherboard is in all respect the king for the price range, though I have heard a few problems w/ quad cores but that won't be a problem. Can't really go wrong with those parts, also, if you don't plan on overclocking it I'd go with an AMD, they have higher stock clock rates.
GL with your build!
Moneyless
Toronto, ON
[...] Can't really go wrong with those parts, also, if you don't plan on overclocking it I'd go with an AMD, they have higher stock clock rates.
GL with your build!
But similarly priced AMD's have much less L2.
I'd go with a E6450 myself because they have the same cache as the E6600's, and recent E6600 steppings haven't been OCing very well. (Taken straight from the mouth of a E6x00 expert from another forum. :) )
J
JayDee
Guest
No PST for Ontario :)
If you can wait 2 weeks there are price drops coming and new CPU's released. Will give you an option for Quad core or one of the new 1333 FSB chips in the same general price range as the E6600 is now.
dheian
Member
Thanks for the info...one of my questions that got missed though: which coolers have been proven to fit well with the EVGA 680i. Some reviews have said it can be a tight fit.
Thanks again!
Mibs
St. John's, NL
If you have questions about the evga 680i board another great resource with some awesome people is the forum at EVGA Forums. There are a few threads there now about cooling the nb and sb and the cpu.
sswilson
Moncton NB
That would be a great place to check.
I think most folks here who are running the EVGA 680i have the cpu sitting under some form of water cooling setup.
That's why you haven't recieved a response to your question.
If you don't get an answer here, but find it on another forum, you'd be doing the next guy a huge favour if you could come back and let us know what you found out....... :)
werty316
I use a Thermaltakes Big Typhoon on an eVGA 680i-SLI motherboard without any issues.
M
Misoprostol
Guest
I honestly don't recommend nVidia chipsets anymore for Intel. If you want a hassle-free experience, just get an Intel-based board...
