Want to Buy CoolLabratory Paste
Elite
Active member
Calgary, Alberta
CoolLabratory Pro or Ultra paste for my delid.
Looking for as local as possible, but will consider having some shipped to me. Not willing to pay the retail price for a used bit.
Lysrin
Nova Scotia
Just checking, which are the correct specs for you current PC, your forum signature or what is displayed under the My System Specs dropdown? If it is you signature then the Core 2 Duo is likely getting a bit dated depending on what you're doing with it.
Moody28
New member
Probably the system specs dropdown, the other one looks a bit old for 2 550 lol
Lysrin
Nova Scotia
Agreed. Just thought I would check because putting money for a newer video card in a core 2 duo... well... :whistle: it might not be money well spent!
Elite
Active member
Calgary, Alberta
Yea I don't even have that system anymore.
As for a budget, with the amount of gaming I actually do is low right now, my budget isn't overly high since I have no need for a ridiculously powerful card.
