core i7 930 + gigabyte GA-X58A-UD3R Rev 2.0
imperatrix
Member
Basicly computer runs fine except for prime 95/ortho's/occt i get errors @ stock , with bios default?
i ran 8 hours of memtest86+ and got 0 errors, pretty dissapointed and curious to know if i should RMA or what. basicly i spend all my time on either wow , BFBC2 , metro2033 never had any issues with said games or anything else.
Cpu : Intel Core i7-930 @ 2.8ghz / 2.9 with intel Turbo Boost Technology
Motherboard: Gigabyte GA-X58A-UD3R Rev 2.0
Ram: Corsair Dominator Series @ 1600 with XMP profile
GPU: EVGA GtX 470 @ stock
PSU: 650w Antec EarthenWatts
HDD 250gb WDD 7200 RPM
Small FFT pass did 2 rounds
Blend/Large FFT fails within minute(s)
MittWaffle
You built this right?
It could be that your heat sink (if its stock) isnt touching the IHS properly, or bad application of thermal paste; that would make it fail.
imperatrix
Member
load temps hit like 80-87c w/ stock HSF full load and IHS? hmm not exactly sure what that is , but yea i built this pc myself if your talking about the chip housing or w/e its sitting flat on the cpu i had that theory myself and reseated the HSF and redid thermal application with some crappy old formula 5 stuff
martin_metal_88
Quebec City
Look at your temp, reseat the CPU and cooler with new thermal paste, make sure the board isn'tshorting with any screw or srandoff. To me this issue is CPU related, maybe try to bump the voltage a bit.
_dangtx_
mtl
install speedfan and look at the graphs. voltage, possibly heat related. although the cpu will thermal shutdown a bit higher than that.
imperatrix
Member
i have 2 fans plugged into molex which is why they arent showing 1 is a system fan that runs PWM but meh
martin_metal_88
Quebec City
Then you should try playing with the voltage a bit up since it don't seems to be a temp issue. Maybe you just got a really bad chip that need a more voltage to work
Zero82z
Montreal, QC
Set the memory to a 2:8 ratio and see if you can pass stress testing. Even though your RAM is rated for those XMP settings, it's possible that it isn't stable as it is.
imperatrix
Member
so set ram to 1333? and that pic is with wow open tabbed out ;] and how much would u suggest bumping vcore? bios has it set to 1.25000 or 1.25625
