Crash Dump
bonanza2000
North Carolina
A friend's computer is only a year or so old and has been working fine. As far as I know, no changes have been made to it. Yesterday it would not come up with windows, it got as far as a screen that said "Loading System . . . . . " and then it would hang. I messed with it just a little and unplug everything from the back except keyboard and mouse. It came up, loaded windows, and I thought everything was fine but now they say it stays up for awhile and the screen goes black and it says "Crash Dump" with lots of characters and then turns itself off. I haven't had a chance to go back and look at it. When I powered it up yesterday the MB gave a 1 beep chirp at POST. The system has a SSD for the OS and traditional HD for data. My gut is telling me its either the SSD or the memory but I was hoping for some thoughts from the peanut gallery before I go look at it again. Any thoughts?
bonanza2000
North Carolina
no ideas from the peanut gallery?
I thought maybe the PSU was bad so I got another one. Computer runs fine for 40 to 60 minutes and then freezes up like it is going to sleep. The screen stays up, if I try to control alt delete to bring up task manager it says something like "preparing security something". Eventually I get a black screen that says "unable to load system insert boot disk" or something like that
so what's that leave me? Motherboard, RAM, hard drive? What's most likely?
Sometimes the computer will power up normally, sometimes I get the unable to load system insert boot disk thing.
Shadowmeph
I think that it is a windows things, maybe try loading it up in safe mode if it loads test it out. or you could try a live Distro of linux and see if the system boots into live linux
bigFOIG
Vancouver, B.C.
I would try booting off of a working windows drive first of all. Or just get your friend to re-install if he doesn't mind. I'm saying this because I hate testing RAM... takes forever.
bonanza2000
North Carolina
Well I have been busy doing things - none of which have worked. They included updating the BIOS of the board to a current F10, new ram, new PSU, installed "whocrashed" which seemed to indicate it was a driver issue afd.sys, reset the winsock thing, booted in safe mode and now the thing won't even get to windows, I get a "loading operating system . . . . ." and nothing else. The new thing is a continuous beep from the motherboard, which I think means a short. So does it sound like the motherboard is shorted to you? Anything else it could be? The cables are all pluged in correctly. Double checked all the connections.
in the beginning I really thought the SSD was going bad but don't think so now
bonanza2000
North Carolina
1 BSOD and partridge in a pear tree
So here is the who crashed output. Does this mean anything to anyone. I honestly don't think the AVG program is the problem. I don't think I have a software issue. I think it is hardware but not sure.
System Information (local)
<HR></B>
computer name: MYPRECIOUS
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 8435908608 total
VM: 2147352576, free: 1974542336
[FONT=Segoe UI, Arial]
<HR>Crash Dump Analysis
<HR></B>
[/FONT]
[FONT=Segoe UI, Arial]Crash dump directory: C:\Windows\Minidump[/FONT]
[FONT=Segoe UI, Arial][/FONT]
[FONT=Segoe UI, Arial]Crash dumps are enabled on your computer.
[/FONT]
[FONT=Segoe UI, Arial]On Sat 12/22/2012 2:39:42 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\122212-37143-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x7EFC0)
Bugcheck code: 0xC4 (0x0, 0x0, 0x0, 0x0)
Error: [FONT=Segoe UI, Arial]DRIVER_VERIFIER_DETECTED_VIOLATION[/FONT]
file path: C:\Windows\system32\ntoskrnl.exe
product: [FONT=Segoe UI, Arial]Microsoft® Windows® Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: NT Kernel & System
Bug check description: This is the general bug check code for fatal errors found by Driver Verifier.
The driver requested a zero-byte pool allocation. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
[/FONT]
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]avgtdia.sys[/FONT] (avgtdia+0x5A16)
file path: C:\Windows\system32\drivers\avgtdia.sys
product: [FONT=Segoe UI, Arial]AVG Internet Security[/FONT]
company: [FONT=Segoe UI, Arial]AVG Technologies CZ, s.r.o.[/FONT]
description: AVG Network connection watcher
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: avgtdia.sys (AVG Network connection watcher, AVG Technologies CZ, s.r.o.).
Google query: [FONT=Segoe UI, Arial]AVG Technologies CZ, s.r.o. DRIVER_VERIFIER_DETECTED_VIOLATION[/FONT]
[/FONT]
[FONT=Segoe UI, Arial]On Sat 12/22/2012 2:37:09 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\122112-39515-01.dmp
[/FONT]
[FONT=Segoe UI, Arial]On Sat 12/22/2012 2:30:11 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\122112-33103-01.dmp
[/FONT]
[FONT=Segoe UI, Arial]On Sat 12/22/2012 2:28:16 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\122112-39827-01.dmp
[/FONT]
[FONT=Segoe UI, Arial]On Sat 12/22/2012 2:26:35 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\122112-44366-01.dmp
[/FONT]
[FONT=Segoe UI, Arial]On Wed 12/12/2012 1:14:11 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\122112-24726-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8008911B30, 0xFFFFFA8008911E10, 0xFFFFF8000359D460)
Error: [FONT=Segoe UI, Arial]CRITICAL_OBJECT_TERMINATION[/FONT]
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
[/FONT]
<HR>Conclusion
<HR></B>
[/FONT]
[FONT=Segoe UI, Arial]7 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
[FONT=Segoe UI, Arial]avgtdia.sys (AVG Network connection watcher, AVG Technologies CZ, s.r.o.)[/FONT]
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
[/FONT]
bonanza2000
North Carolina
HWMonitor report. I can't tell anything from this, can you?
CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.1.0
Monitoring
Mainboard Model Z68XP-UD3 (0x00000269 - 0x02E13294)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 28 01 00 00 00 F7 10 00 00 00 48 80 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 1.04 Volts [0x57] (CPU VTT)
Voltage 1 3.34 Volts [0xA9] (VCC3)
Voltage 2 12.17 Volts [0xF8] (+12V)
Voltage 3 5.04 Volts [0xF5] (+VCC)
Voltage 5 1.24 Volts [0x67] (CPU VCORE)
Voltage 6 1.50 Volts [0x7D] (DRAM)
Voltage 7 3.38 Volts [0x8D] (+3.3V)
Temperature 0 29°C (84°F) [0x1D] (TMPIN0)
Temperature 1 25°C (77°F) [0x19] (TMPIN1)
Temperature 2 37°C (98°F) [0x25] (TMPIN2)
Fan 0 1383 RPM [0x1E8] (FANIN0)
Fan 2 1078 RPM [0x272] (FANIN2)
Fan 3 1032 RPM [0x28E] (FANIN3)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 13 10 00 00 FF FF 00 37 FF 87 64 0F 17 E7 FF 72
10 FE FE FE 76 C7 82 80 82 01 FF 02 FF FF FF FF FF
20 58 A9 F8 F5 58 66 7D 8D 89 1D 19 26 B9 C0 F3 F3
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 3C 7F 5F 40 AD 6A D4 00 FF FF FF FF
50 FF F8 7F 7F 3C C0 58 58 90 58 3D 12 65 00 00 00
60 00 14 41 46 1C 03 00 FF 00 14 41 46 20 03 00 FF
70 00 14 41 46 1C 03 00 FF FF FF FF FF FF FF FF FF
80 8D 02 00 00 FE FF 00 00 02 30 01 02 01 0D 20 81
90 FF 00 00 00 FF 00 00 00 40 00 00 00 00 E8 00 23
A0 CE F3 F3 F3 F3 F3 F3 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Gigabyte DES
Voltage 0 1.24 Volts [0x67] (CPU)
Hardware monitor NVIDIA NVAPI
Voltage 0 1.10 Volts [0x44C] (VIN0)
Temperature 0 31°C (87°F) [0x1F] (TMPIN0)
Fan 0 1980 RPM [0x7BC] (FANIN0)
Fan PWM 0 45 pc [0x2D] (FANPWMIN0)
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.330 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 2600
Codename Sandy Bridge
Specification Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
Core Speed 3510.3 MHz
Multiplier x FSB 35.0 x 100.3 MHz
Stock frequency 3400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 34x
Max turbo ratio 38x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins +4
Ratio 1 core 38x
Ratio 2 cores 37x
Ratio 3 cores 36x
Ratio 4 cores 35x
TSC 3409.9 MHz
APERF 3510.1 MHz
MPERF 3410.0 MHz
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020101h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000206A7 0x00100800 0x1FBAE3FF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B2FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x20202020 0x65746E49 0x2952286C
0x80000003 0x726F4320 0x4D542865 0x37692029 0x3036322D
0x80000004 0x50432030 0x20402055 0x30342E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850081
MSR 0x000000CE 0x00001000 0x70012200
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x23242526
MSR 0x00000194 0x00000000 0x00090000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88320000
MSR 0x000001FC 0x00000000 0x0004005C
MSR 0x00000601 0x18141494 0x000008C0
MSR 0x00000602 0x18141494 0x000008C0
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000610 0x0000A580 0x00008960
MSR 0x00000611 0x00000000 0x1A613F89
MSR 0x00000639 0x00000000 0x160310AC
MSR 0x00000641 0x00000000 0x0066CCC5
MSR 0x00000614 0x00000000 0x01E002F8
MSR 0x0000019C 0x00000000 0x88320000
MSR 0x000001A2 0x00000000 0x00621200
MSR 0x00000198 0x0000285A 0x00002300
MSR 0x00000199 0x00000000 0x00002600
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000206A7 0x01100800 0x1FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000001B1 0x00000000 0x88310000
MSR 0x00000611 0x00000000 0x1A628503
MSR 0x00000639 0x00000000 0x16042CD5
MSR 0x00000641 0x00000000 0x0066CFA1
MSR 0x0000019C 0x00000000 0x88330000
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020101h
CPUID
0x00000001 0x000206A7 0x02100800 0x1FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x00000611 0x00000000 0x1A63D57F
MSR 0x00000639 0x00000000 0x16055280
MSR 0x00000641 0x00000000 0x0066D299
MSR 0x0000019C 0x00000000 0x88350000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000206A7 0x03100800 0x1FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x00000611 0x00000000 0x1A65115F
MSR 0x00000639 0x00000000 0x16066F2D
MSR 0x00000641 0x00000000 0x0066D591
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020101h
CPUID
0x00000001 0x000206A7 0x04100800 0x1FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x1A665683
MSR 0x00000639 0x00000000 0x160780D2
MSR 0x00000641 0x00000000 0x0066D858
MSR 0x0000019C 0x00000000 0x88310000
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000206A7 0x05100800 0x1FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x1A679888
MSR 0x00000639 0x00000000 0x160899CA
MSR 0x00000641 0x00000000 0x0066DB50
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020101h
CPUID
0x00000001 0x000206A7 0x06100800 0x1FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x000001B1 0x00000000 0x88340000
MSR 0x00000611 0x00000000 0x1A68DA7E
MSR 0x00000639 0x00000000 0x1609B27D
MSR 0x00000641 0x00000000 0x0066DE17
MSR 0x0000019C 0x00000000 0x88370000
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000206A7 0x07100800 0x1FBAE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0x1A6A1B09
MSR 0x00000639 0x00000000 0x160AC9D8
MSR 0x00000641 0x00000000 0x0066E0F7
Storage
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x0024
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC05A
USB Device USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x0781, product=0x5567
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY3
Name Intel HD Graphics 1000 (GT1)
Technology 32 nm
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1458)
Model ID 0x0102 (0xD000)
Display adapter 1
Name NVIDIA GeForce GT 440
Revision A1
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1458)
Model ID 0x0DE0 (0x3518)
ACPI
ACPI Tree
KaptCrunch
Ontario
Bonanza2k
what REVision is you motherboard 1.1 or 1.3 for Z68XP-UD3 has 2 versions of that model name
sounds if software issues
best back-up data and do fresh install with current drivers for MB that ever REV it is
bonanza2000
North Carolina
Bonanza2k
motherboard is 1.3
it has the most uptodate BIOS
problem is the computer doesn't stay up long enough to do a good back up. that said the data is on one drive and the OS is on another and I don't think it is the drives
i am not sure how it could be software related since the computer has been up and running for 2 years and no new software has been added to it. there is very little on this machine. Windows is up to date.
I pulled the graphics card and only used 1 stick of RAM and that didn't make any difference
i was planning on doing a new build and I am thinking of putting the existing CPU and OS hard drive on an new motherboard that I have over here (same manufacturer but different board GIGABYTE|GA-Z77M-D3H-MVP Z77 R) to see if it is the motherboard. Think that might work? or at least indicate that it is a motherboard issue?
also thought about sticking a new HD into the old machine and reinstall windows and see if plays pretty which would rule out the hard drive and windows as the root cause.
just not sure which direction to go from here . . . . still pondering on it.
