Crashing in BC2
Nevakonaza
UK
Hey guys,
Appreciate some help here because im lost.
For the past 4 times ive tried playing BC2 it crashes and i have to hard reboot....im not sure whats causing it because ive been playing BC2 for months on this rig no problems at all...i get around 95-105 fps maxed settings in DX11.
My system temps are fine,Although looking at event viewer it shows Event ID41?
Im not sure what it means!
My system specs are-
Core i7 860 @ 4Ghz (HT OFF)
Prolimatech Megahalems Rev. B- 2x Yate Loons
Gigabyte GA-P55-US3L
4GB G-Skill Ripjaws 1600Mhz CL7(7-8-7-24)
XFX HD 6950 2GB GDDR5 (Shader Unlocked)
OCZ Vertex 2 60Gb SSD
WD Green 500GB (Storage)
Seagate Barracuda 250GB (Games & Apps)
Asus Xonar D1 Sound Card
OCZ ModXStream pro 600W Modular
Coolermaster CM690 (Window Modded)
7 Home Premium X64
Arinoth
Halifax
Have you tested your overclock to ensure it is stable for both the cpu and ram? Have you done memtest86 to ensure the ram in itself has no issues with it. Finally, have you stress tested your graphics card as well? Any of these three along can cause crashing while gaming and i recommend testing each out to see if they all pass.
