Crashing
Acrid
Member
Ever since i downloaded games on my newly build PC the steam games tend to crash most of the times. For example while im playing PUBG after 10-15 mins it randomly crashes. Or when im playing CS it sometimes (rarely) crashes but then won't let me join back in. After a month still haven't found something to fix this issue.
Acrid
Member
Temps normal, disabled all applications and ran a clean boot and they still crashed so im thinking it isn't software related.
KaptCrunch
Ontario
Try one only 1 stick of RAM at a time to see if still crash
Also remove optical drive data/ power cable
For seen that happen bad CD drive
MvSlainXVII
Active member
Can you send me the full PC specification here. I think you need to do some diagnostic on your PC, worst case can be that you might have a failing VRM on the motherboard which might cause the system to crash. Have you overclocked the CPU?
