I can't see any of the images.
also, from what Rikan said, his problem is that he doesn't see the "enable Crossfire", it's missing.
I could be wrong but from what I understand this is what he sees (under Gaming, Crossfire isn't there);
are the card same brand and model
I actually don't see those values in the same spot on my machine...As you can see the crossfire entries in your reg. are not in mine. You maybe onto something.
So I tried adding the two crossfire entries you have in your registry with the value of zero. The reg saves it after reboot, but it doesn't fix the issue. Still no crossfire toggle to be found.
I also bit the bullet and reinstalled Windows 7 and that didn't help either. Even on a freshly installed OS, the crossfire toggle is missing.
