mello_newf
Active member
So I have come to the realization with my rebuild that I now have enough extra parts to do a custom build with watercooled CPU/GPU. Wondering what people think it might be worth as a fully built system?
I have a pretty good idea what I can get by parting out but I would rather get rid of the bulk of it in one go locally (GTA) and I get something on the side to mess around with.
CASE = Lian Li PC-V354B (Side panel modded for viewing window) (PSU mounts removed/relocated) (HHD cage cut down)
LINK = LINK
RAM = Gskill 2X2GB DDR3 1600
LINK = LINK
PSU = SILVERSTONE ST45SF 450W (maybe 48hrs of use)
LINK = LINK
MOBO - ASRock Fatal1ty Z77 Professional-M (2 out of 4 USB 3.0 ports in the back do not work and never have, it's a knows issue as they used 2 controllers and one was crap)
LINK - LINK
GPU = EVGA GTX 480 (with EK fullblock and evga backplate)
LINK GPU= LINK
LINK BLOCK = LINK
CPU = Intel Core i3-2120 (with rainstorm W/C block) (few months of usage)
CPU LINK = LINK
BLOCK LINK = LINK
HDD - 1TB WD BLUE 7200RPM (about 1.5 years old very little usage)
LINK = LINK
Pump - DDC with XSPC pump top res (1.5 years of use)
PUMP LINK - LINK
RES LINK - LINK
RAD - 1X 240mm swiftech (Lian Li 3pin fans x2) 1X 120mm XSPC (Noctua 3pin fan x1)
SWIFTECH LINK = LINK
XSPC LINK = LINK
Fittings - Phobya compression fittings (str,45,90)
LINK - LINK
Lights - Case has some darkside RED lights that I will keep in there
Also has a blu-ray drive
LINK = LINK
LINK = LINK
LINK = LINK
LINK - LINK
LINK GPU= LINK
LINK BLOCK = LINK
CPU LINK = LINK
BLOCK LINK = LINK
LINK = LINK
PUMP LINK - LINK
RES LINK - LINK
XSPC LINK = LINK
LINK - LINK
