Dashocks water cooling with "The Vortex Solution"
magictorch
Annapolis Valley, NS
Yea I cant see the water moving either in mine at all. Those temps look good for a stress test with those volts-have you tried core temp as well? Youll probably be at about 38oc for gaming:thumb:
Dashock
Toronto
So do you consider the temps of the individual cores as your overclock temps or just the cpu temp?
sswilson
Moncton NB
On intel chips, folks use core temp as nobody is really sure what the cpu temp is reporting.... :)
Not sure what folks use on AMD chips.
Dashock
Toronto
SSWilson do you think these temps are good i mean im the coolest part of my house im a little disappointed but im also only running 2 fans so im gonna hook up too more lol i was expecting a little more :p
magictorch
It really depends what the chip was like temp-wise with a similar test and OC before--im guessing you have an improvement-my opteron couldn't hold temps like that at that speed in stress tests. Are your fans in push or pull?mine are pushing. You could always reseat the block.
sswilson
Moncton NB
Temps look fine to me for load temps, but as magictorch has already mentioned, it's hard to say for sure without some kind of reference temperatures on air.
Dashock
Toronto
i think its aboot 5 degrees less then on air and magic im doing a push at the moment im gonna add 2 more fans for a push-pull but i wanted to long tests to see temperature difference between the two setups. cheers
Dashock
Toronto
well the good news is i was able to boot the comp to 2800mhz it did not pass Prime 95 but i wonder if it would be stable playing games i ran it for an hour of just normal usage downloading and browsing and worked fine but ill test it with crysis im gonna leave my comp here in the basement for the rest of the week i was just hoping for a little bit better my room upstairs on the third floor is way too hot that i dont think i would get such good temps compared to me being here in the basement.
