I have purchased a couple DDR5 kits for other people without issue based on common sense of the advertised freq/timings/cost. That said, I haven't really looked into the DDR5 situation for what kits (or which companies chips on the sticks) are offering the best ability to OC or tighten timings.
If being more specific is required, I suspect I will be looking for 2x16GB and 6000mhz (doesn't matter if its advertised to that speed or tweaked) with the tightest timings possible, and within a reasonable price point. It would be nice if the kit is expected to be able to OC higher for potential future use cases.
- Is anyone swept up on DDR5 to give some general guidance on if certain kits are the standout preference, or is it luck of the draw?
- I suspect this is likely heavily dependent on the actual memory chips. Are you able to do a quick coles-notes of these for DDR5?
- Anyone have or know of a compiled list of DDR5 kits/memory chips and what are preferred ones as a quick reference?
