Dear mother of god
severity
Vancouver
okay so for the past 4 years or so I've been installing windows via a hard drive i mean who needs opticals those are so 2007. now the problem is I've run out of hard drive space in my case and I cant keep this awful 200GB sata 1 HD with the windows 7 install on it in my case anymore so I'm trying to get the boot manager off of this one hard drive and onto the main OS drive, now i've tried the following and bootsect say's it completed it successfully but it's a :censored: liar and soon as i unplug the hard drive windows wont boot.
nt60 c: /mbr
nt60 c: /mbr force
nt60 ALL /mbr force
nt60 mbr c: force
nt60 c: force /mbr
now clearly I'm doing something wrong :ph34r:
getting accessed denied when i try
{"nt60" or "SYS":ALL<C:> /force /mbr
JD
Toronto, ON
It won't do anything if it finds a working bootloader if I recall.
Put your Windows 7 media onto a USB key (Install Windows 7 with a USB Key), boot from that, and chose the Statup Repair or whatever it's called. It should automatically fix it for you. Otherwise you can pull up a command prompt and enter those commands from there.
severity
Vancouver
:$ i tried doing this first but it just said that the files were corrupt on the USB key guess ill try a different ISO?
NyteOwl
Nova Scotia
Boot a Linux Live CD and use dd to copy over the boot sector. Just watch you don't overshoot.
