Dell G5 worst than Walmart PC?
lowfat
Grande Prairie, AB
I definitely have m3x20mm. I'll be trying to install a Noctua NH-L12 when I decommission my existing server. But it it don't fit, o well. TBH my CPU will probably sit at sub 5% load 99.9% of the time.
anabioz
Montreal
I definitely have m3x20m. I'll be trying to install a Noctua NH-L12 when I decommission my existing server. But it it don't fit, o well. TBH my CPU will probably sit at sub 5% load 99.9% of the time.
It's that 1% you'd want to count when the CPU Frequency spikes and the load kicks in :)
lowfat
Grande Prairie, AB
Finished the drive cage mod. Trying both the rear and fan as intakes and use positive pressure for an air to find way out. GPU temps are 3C loader. Everything else is a few degrees warmer.
i5-10400F
64GB 2133MHz DDR4
RTX3060Ti
16GB Optane NVMe boot drive.
256GB Samsung 950 Pro for LXD containers and VMs down the road if needed.
2 x 10TB Seagate Barracuda Pro in ZFS mirror
sswilson
Moncton NB
NIce, I could have used that when I got my G5. I removed the HDD to make room for a front fan and installed a 2.5" SSHD instead, but would have just moved the HDD to this if it had been available... :)
anabioz
Montreal
i5-10400F
64GB 2133MHz DDR4
RTX3060Ti
What are you running on this beast, what OS and what is the use-case?
lowfat
Grande Prairie, AB
Ubuntu Server 21.04. It is replacing an i3-3220 ITX system as my home server. Runs a few of containers for media + home automation (plex, sonarr, jackett, rtorrent, mqtt, node-red, unifi, upsmon).
The RTX3060Ti is just for mining.
anabioz
Montreal
got it, makes sense. I was going to suggest truenas scale (debian based).
