Dell t7400 - 8 pin problem
Hi, I have a dell precision t7400 which uses a special propietary PSU.
I wish to use my r9 290x which requires one 8 pin and one 6 pin.. however, the 8 pin connector on my PSU does not fit the 8 pin connector on my GPU!! I read it is not for gpus but rather riser boards so..
Ideas??
supaflyx3
Langley, BC
A R9 290x will be heavily bottleneck in a T7400, you'd be better off upgrading to something newer
Would it be appropriate to move this to the power supply section or should I just make a new thread there
supaflyx3
Langley, BC
I would advise against it. That PSU only provides 18A per 12v rail. The 290x can draw up to 25a, there's a high chance you'd blow your PSU and video card.
KaptCrunch
Ontario
use at own risk due to fire, shortted hardware
OP still hell bent to run that card on dell precision t7400
disclaimer: not responsible for fire hazard, if not protect all connections from shorts (killing hardware)
can use another PSU dedicated to the R9 with Dell PSU by the green (16) and a black (15) wire together with matching colour wire on dedicated PSU plug
enaberif
Calgahree, AB
I made such an adapter and it isn't hard but you need to definitely know your stuff.
