gingerbee
Damn even Philly D is talking about this, this won't be good for Nvidia.
@17:58
@17:58
Derbauer says in his video that it's a quality cable from MODDIY(never runs after-market cables so can't speak on this). He runs his 5090 doing a test with his build using a Corsair PSU and cable, getting the same results as the burnt cable. I don't see how the cable itself could cause power to flow through one wire unless the cables themself were damaged. very strange cause what I know about current/power is it should flow through all the cables equally, I am not sure how this is even possible, clearly it is.Just curious.. out all of these failures..
How many were using Seasonic PSUs?
Just saying, the cable and plug look pretty cheap to my 4 eyes on this big screen.
isn't PCIe sig just specs for signalling/communication/power between board and card through that connection, not secondary power delivery. ???if they follow the spec laid out by pcie sig /nderpia and it still burns who's at fault![]()
PCIE-Sig is the standards organization both for the board connector and the power delivery (either via board or the psu connection) IIRC. That being said, Nvidia likely has a lot of personnel on the standards board so there was likely quite a bit of cross talk between the two.isn't PCIe sig just specs for signalling/communication/power between board and card through that connection, not secondary power delivery. ???
