Difference between Asus P8Z77-V and P8Z77-V LX and P8Z77-I DELUXE?
kasabian
New member
Advice please.,,,,,,So many Asus p8z77 boards!
What is the difference between the Asus P8Z77-V and P8Z77-V LX and P8Z77-I DELUXE motherboards (apart from wi-fi)?
And are these the best choices for this price range?
Thanks.
lowfat
Grande Prairie, AB
The P8Z77-I DELUXE is ITX.
P8Z77-V LX is slower lower range than the non-LX. The P8Z77-V has better onboard sound + LAN, has wifi, has a few extra sata. Depends if the money to you is worth the difference.
kasabian
New member
Thanks for your help. The thing is, i will be using dedicated sound and PCI cards anyway, so i don't know if the P8Z77-V has anything else to offer for the extra cost. Also i'm not sure how the performance/features of the P8Z77-I DELUXE compares to the P8Z77-V LX?
moocow
Vancouver, BC
These days, you buy motherboard for features and overclock abilities. Given the same CPU and GPU at default settings, motherboards of the same chipset more or less run within a few percentage of each other. P8Z77-I Deluxe will probably not be your board because it only has 1 PCI-E 16 slot for GPU, or any PCI-E card.
Multi-GPU: V-LX doesn't support SLI but only Crossfire so you are stuck with AMD GPU. V appears to do both.
PCI-E: V-LX only has 1 PCI-E x16 slot, the other one is a x16 slot but runs at x4 only. V x16 slots will run in x8.
PCI: V-LX has 3 PCI slots but V only has 2.
Wireless: V has wireless card built in
SATA: V has 2 more SATA port
Audio: V has a better audio chip, not that it matters in your case
Overclock: not expert in this area but V has a 12 phase power instead of 6 phase in V-LX
ZZLEE
KANATA
I is Minni ITX
onboard sound is descent to exealant :biggrin:
