Does overclocking reduce product life?
kingnubian
Montreal
Properly overclocking, (Paying close attention to cooling, voltage, MB, PS, ect), will probably allow your cpu to last longer than you care to keep it. I have always overclocked my systems, from the old Celeron 300mhz to my E6420 today (3.4Ghz) & all my AMD & Intel processors in between, and have never had a CPU failure.
ebdoradz
Rouyn-Noranda, QC
processors are are built with a lifespan of about 20 years.
they are also develloped to work @ a voltage, and if you look at the processing method (45nm ... etc.) the smaller it is, the lower the voltage is. all that because the smaller the cpu are made, the transistor are smaller and the distance between those is also smaller.
in every cpu there is electron migration and thats normal. but if the vcore is increase by a good margin then you will accelerate the electron migration and you cpu will die faster.
in order to stay with a good lifespan of your cpu, keep the temps and the volt the lowest possible
heres the explaination of eclectron migration Electromigration - Wikipedia, the free encyclopedia
