Don't know where a certain front-panel case cable is connected
odis172
Ottawa, ON
Thats a usb connector. Plug it into the usb header, in the row with the 5 pins. When your looking at the motherboard with the usb ports on the bottom, the red should be on the left. Its an odd connector, you most likely have just one front usb port
KaptCrunch
Ontario
Here is a pic of what the connector looks like. I'm sorry if it looks a little fuzzy
first fucus your cam by turning the lens outer ring like a screw
then place the part on a white paper and take a lamp to give light on part then grab camera an snap a shot
SugarJ
Langley, BC
It's a single USB port connector. My Silverstone has ones like that. It can be plugged into half a 10-pin usb connector on your motherboard. The empty ground goes where the missing pin is in the connector.
