Double boot + Hang
Duck2h
Member
Hi Guys,
I have just built a new system which consists of:
Asus P7Z77- V Pro
Intel I5 2500k (OC to 4.5 Ghz)
8Gb Vengance Corsair RAM
GTX 580 MSI
120gb Intel 520 SSD
I have been getting this issue where on boot, i notice the LED light on the CPU stays there and then the computer resets. Once it resets, it hangs on windows load screen. This issue occurs once every 15 boots or so.
I have tried to turn off PLL overclocking in BIOS as most people have suggested, and it makes my computer auto hang on windows all the time. I have also enabled Boot by PCI-E in Bios but it has not helped.
I need some help, its driving me crazy!!
masterboxbuilder
Active member
calgary canada
mystery double boot
i know its not the same but, I have a p8p67 pro and my board does the same thing too except more like once a month it occurs. It did it more frequently on my board before the b3 revision. I couldnt tell you if it does it on stock speeds because i o.c.'ed my 2600k the day i got it and have left it since. My oc is stable for long runs of prime 95 and never crashes or hangs during anything else. I kinda gave up trying to figure it out and just figured its a asus specific problem, and it always boots.... eventually.
3.0charlie
Bedford QC
You have a folding tag, Masterbox. Set up a SMP Client, and let it rip. This will show if your oc is really stable.
My own oc was stable with Prime, and Linx. But not for SMP folding...
dandelioneater
Kelowna, BC
Are you on the factory bios? There appears to be an update for that board:
<table width="100%" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td width="79%" bgcolor="#FFFFFF"> Version 0906 </td> <td class="align_R" width="21%" bgcolor="#FFFFFF">
</td> </tr> </tbody></table> <table width="100%" cellpadding="5" cellspacing="1"><tbody><tr><td class="word-black-12" align="left" width="26%" bgcolor="#E0E0E0"> Description </td> <td class="word-black-12" align="left" width="74%"> P8Z77-V-PRO BIOS 0906
1.Improve system stability.
2.Improve memory compatibility.
3.Fix S4 resume fail with Windows 8.</td></tr></tbody></table>
Don't update unless you have exhausted all other possibilities (unstable OC, bad bios setting, etc)
