Dram_led light, failure to post
Muad'Dib_53
I built my new system yesterday, and did it very slowly and carefully. I read my mobo manual, watched videos on Newegg and NCIX on how to build step-by-step, made sure to touch a metalic surface frequently, etc. I did not put too much thermal paste (MX-2) before installing the heatsink (CM Hyper 212 Evo) which is well in place. I didn't do anything wrong with the standoffs.
When I powered on the beauty, the CPU_led was lighted, but then quickly realized I had forgotten to plug in the 8-pin ATX power connector. Now, I re-checked all the SATA and power cables, made sure everything was plugged properly including the monitor. The CPU fans are also connected.
Then the CPU_led disappared but the DRAM_led is now red, and nothing appears on the monitor. The fans spin. But no post. I tried with one RAM module, tried all the memory slots, switched the RAM and did the same but to no avail. I pressed Memok with the 2 sticks of RAM and then with each one. The led flashed for a little while and then nothing. DRAM led still lighted red, no VGA signal.
I guess I could by that my RAM (G.Skill F3-12800CLD9-8GBXL) is not on the QVL. But I had looked around in the forums and everyone was saying they did not have any problem with this RAM and Mobo combo.
Also, perhaps that's just the color Asus choose, but the power on switch on the Mobo is red, nothing green.
I spent hours yesterday looking at troubleshooting threads. Frankly, I do not know what to do. I hope it's not the Motherboard; what a pain.
So what should I do? RMA the memory? Bring the system to a local technician?
Here are the specs:
Asus P8z68-v /GEN 3
i5 2500k
CM Hyper 212 Evo
Crucial M4 128 GB
WD 2 TB Green Sata3
Antec True New 650W Semi-modular
Asus DVD burner
Corsair 400R
(I am waiting for my Gigabyte Radeon 7850)
Please help!
Thanks so much in advance.
Adzsask
SK
If you can, try a different graphics card, I have had 2 DOA videocards in the last 2 months (EVGA 560Ti 2win, EVGA590) and would not post without a working GPU.
Muad'Dib_53
My video card is not yet installed i.e. I tested the system without a GPU card.
Muad'Dib_53
I wanted try the system, to see if it would post, using integrated graphics, while my GPU was being shipped. Would you say that this could the cause???
KaptCrunch
Ontario
you need to reset bios
first remove wall power cord from PSU, then push start button to drain power. then move CLRTC jumer to 2-3 from 1-2 wait 20 secondsthen put back to 1-2 position
those CPU power connections make sure use the left side if have one CPU power plug and the YELLOW wire is on the lock side of plug
no worries for its defaulted to boot onboard
i see a bios update Version 3201 is current with memory fixes , just wait till you get a boot screen to verifi bios version
Muad'Dib_53
Thanks, I tried this before but without draining power. Will try again.
I am not sure to understand what you mean... Please explain.
Thanks.
Muad'Dib_53
I did like you said.
Nothing changed. Fans spinning, no VGA, DRAM led lighted.
:sad:
KaptCrunch
Ontario
posible cpu.....toasted?
:sad:
you have a system speaker working to listen to beeps while booting?
and the 4 boot LEDs show what order are lighted 1,2,3,4
Muad'Dib_53 where you live? maybe a HWC member close to you can help
Muad'Dib_53
I have a normal 2.1 system speaker, that was not connected... Will try this after lunch.
I live in Montreal.
Thanks for your help.
