Dual Channel RAM issue
Safearus
SSM, Ontario
Hey everyone, as my worklog now states my rig is up and running but I cannot find the camera anywhere...
However I'm having one issue. Right now I'm unable to get my RAM running in dual channel mode. It's only running in single channel no matter which placement I use on the motherboard.
I've tried both of the following and neither worked :angry2:
[0] [1] [2] [3]
[X] [ ] [X] [ ]
[X] [X] [ ] [ ]
Any suggestions?
KaptCrunch
Ontario
what version of bios you have now ?
for version 0803 has fixes for memory and current is 0903 asus D/L
also (Ram) for MB QVL the muskin p/n is 996657 (4gig(2gbX2) 7-7-7-20 pc1600 and 998659(6gig(2gbX3)9-9-9-24 pc1600
Safearus
SSM, Ontario
Right now I'm still on 0302 :rofl:
Didn't even think of that being the issue.
Would the ASUSUpdate utility actually be useful here? Or should I find a USB key and update it that way? I've NEVER done a BIOS update, LOL
Nademon
Toronto
I just use the USB key method. EZ flash has always worked wonderfully for my bios updates.
KaptCrunch
Ontario
ASUSUpdate utility
must have good connection and stable system
also use a UPS(uninterruprtable power supply) incase loss of power while programing bios....resaults DOA MB
WARNING if not confident usb flashing... have someone you know do it for you that has sussfully done in past
Make Sure you Have the Correct Bios for your MB model and version of MB (eg V.1, V.1.2)
Safearus
SSM, Ontario
Done, updated to 0903 without any issues using EZ Flash! Just saved to my spare HDD and stuck in in the eSATA port. Issue still not resolved... *opens up his motherboard User Guide for the first time...*
Edit: Well, need to power down and re-locate the memory into the first two slots. ASUS did something right and put the dual-channel slots side-by-side instead of staggered... I was wondering why the color coding for the dual channel wasn't existant... time to move one module and see if the new BIOS makes a difference. Will update when done.
Safearus
SSM, Ontario
Alright, thanks for the help guys! Issue is now resolved, 4GB (2x2GB) Now running in dual-channel!
Nademon
Toronto
good stuff! I know I'd be irritated if I couldn't get DDR to work. Glad you got it up and running.
