Dual monitor stand screw
londiste
New member
For standard VESA 75x75 or 100x100 (which are the likely ones for a monitor) spec says M4 screw and hole should be 10mm deep.
Bigger VESA mounts need bigger screws, M6 with the same depth for 200x200 and M8 and 15mm for 400x400 and above.
