Edifier M3400 2.1 Review Comments
sswilson
Moncton NB
Looks like a pretty decent set of speakers for $60.
Have you had a chance to listen to the logitech low-end X-230 2.1 series of speakers? If so, how would you rate these when compared to them?
The logitechs can normally be found for sub-$50, but certainly aren't made out of wood.
Amon
Brampton, Ontario, Canada
Not too bad. Maybe won't sway me from my choice of M-Audio StudioPro 3, but they seem like a deal at $60 with the added benefit of wooden enclosures and a subwoofer. As usual, the review was thorough and very insightful. Great stuff!
P.S.: How are the highs in comparison to a set of Creative T40? The sub seems a bit heavy...
Zerofx
New member
Question about speakers.
I wanted to know if you could plug in a microphone in the auxiliary input on the volume pod?
For certain games i like to use my headset it has a mic on.
Thanks for your help
:thumb:
Robscix
Ontario, Canada
NO. The Aux input on the Volume pod is for MP3 players...CD..etc. If you game with a mic connect it to your soundcard or from audio connection on the case if they work and you have them.
Zerofx
New member
Thanks for the reply. That is how i have it setup right now. i guess i will just have to run an extra cable from the soundcard up to desk.
Thanks again :thumb:
Robscix
Ontario, Canada
Glad I could help. How do you find the sound quality? Did my review help you decide or did you laready own the system? -Just curious.
bigpino
Active member
Ottawa
Awesome review :thumb: . Still deciding on these speakers or r541 for my brothers. I have the edifier S5.1. It is the sex :punk: :whistle: .
