Extreme OC Build
Infiniti
Vancouver, BC
Hey all. I'm building another new computer, but then since I'm using this one solely to OC, what would be the cheapest build, but can be used later on for other uses? I'm going to give this to my brother after when I'm done with it.
So, I need a build that is best for OCing (Min 4Ghz, using dry ice) while cheap, and can be used for gaming after)
My budget is about 500$.
enaberif
Calgahree, AB
thats not exactly uh .. extreme?
dry ice? hahaha.
just buy a 8400 and clock to 4 on air :p
6ghz is extreme as a minimum.
rjbarker
Courtenay, B.C
What temps? What Cooling method yada yada yada.....
Personally, I'd go with the E8400 ($180) and hope for a "good chip" ....
rjbarker
Courtenay, B.C
Go to 1.5v...!!! Push it man...throw your money away..hahahahah
Just kidding...like my "older" E8400, cannot get it past 4.05 Ghz without pushing well past 1.45v, although, they're cheap enough now...hhhmmm...know where I'm going with this?
