Final Build after careful consideration!!!
NOOBUNIT
Member
Motherboard – Asus P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 Crossfire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard
http://www.ncix.com/products/index.php?sku=30418&vpn=P5Q%20Pro&manufacture=ASUS
Price - $158.54CAD
CPU - Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB Retail
http://www.ncix.com/products/index.php?affiliateid=4352418&sku=27784&promoid=1066
Price - $173.99 CAD
Video/GPU - Visiontek Radeon HD 4870 X2 750MHZ 2GB GDDR5 2XDVI HDTV PCI-E Video Card
NCIX.com - Buy Visiontek Radeon HD 4870 X2 750MHZ 2GB GDDR5 2XDVI HDTV PCI-E Video Card - 900250 In Canada.
Price - $599.99 CAD
Ram - Mushkin Ascent PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 240PIN Dual Channel Memory Kit
http://www.ncix.com/products/index.php?sku=30218&vpn=996619&manufacture=MUSHKIN
Price - $139.99 CAD
Power Supply Unit – Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 120MM Fan
http://www.ncix.com/products/index.php?affiliateid=4352418&sku=26415&promoid=1043#Specifications
Price - $114.99 CAD
Hard Drive – Seagate Barracuda 7200.11 640GB 3.5IN SATA2 7200RPM 32MB Cache NCQ Hard Drive *5YR MFR Warranty*
http://www.ncix.com/products/index.php?affiliateid=4352418&sku=31404&promoid=1066
Price - $79.99 CAD
CD/DVD Drive – Samsung SH-S203N Black SATA DVD+RW 20X8X16 DVD-RW 20X6X16 DL18X/12X Lightscribe DVD Writer OEM W/ SW
http://www.ncix.com/products/index.php?sku=26371&vpn=SH%2DS203N%2FBEBN&manufacture=Samsung
Price - $34.54 CAD
HSF – [OCZ Vendetta 2 Triple Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 120MM Fan 800-1500RPM 20-32DBA
http://www.ncix.com/products/index.php?affiliateid=4352418&sku=29311
Price - $39.99 CAD
Case – Xion XION2-SL Silver ATX Mid Tower Case 4X5.25 2X3.5 5X3.5INT 2X120MM Fans 450W W/ LED Fans & Window
http://www.ncix.com/products/index.php?affiliateid=4352418&sku=15438
Price - $95.43 CAD
Monitor – Acer AL2216Wbd Black 22" Widescreen TFT-LCD, 1680 x 1050, 700:1, 5ms, Analog, DVI-D (ET.2216B.0D0)
http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=011005&cid=MT.282
Price - $199.99
Mouse – Razer Copperhead (from canadacomputers store nearby my house =P)
Logitech G15 2ND Gen Gaming Keyboard USB Black Silver Amber LCD Panel Programmable Backlit Keys
http://www.ncix.com/products/index.php?affiliateid=4352418&sku=26151&promoid=1065
Price - $59.99 CAD
Ok, plz help make any final suggestions or anything im missing, also anyone know about the shipping and everything related to that for buying online at ncix.com cause im kinda scared >.<.
Special shout outs go to - Geokilla and SugarJ (SAVED ME MONEY XD AND HELPED ME CHOOSE A CASE OF MY LIKING O MAN CANT STRESS THAT ENOUGH)
Dwayne
Courtenay, BC
I think you will be a very happy camper when the parts all come together! I see no OS, will you run Vista 64 or XP 64 or something else?
Congrats!
NOOBUNIT
Member
hey its dwanye ive come a long way =P, yea i think XP probably everyone says vista's extra features arnt very helpful and it only allows for the direct X 10 =_=
Dwayne
Courtenay, BC
Heh, I have many of the same components and if you check my sig you'll see I have a modest 20% OC on the CPU. Does it add a lot of speed? Who cares! The thrill of trying and hoping nothing blows up, that's the ticket. :thumb:
My OC is a very modest FSB increase to 400 MHz. As I was increasing the FSB I kept my RAM at or near the 1066 rating they have. My Vid is set to 1.24v and showing 1.23 in HWMon and 1.232 in CPU-Z.
Synth
Ottawa-Hull
Website
www.plctech.ca
Everything looks good, except for the motherboard and case :
1. Make sure your HD4870 x2 will actually fit in the case (case came out in 2005... looks smallish)
2. Maybe Biostar I45 or Asus P5Q-E over the P5Q-Pro...
My .02 :biggrin:
Dashock
Toronto
Yes i would suggest the Asus P5Q-E as well its only a few bucks more and so far its been a pretty solid motherboard. PLUS ONe for EPU-6 Engine it saves me energy when folding and gives me the boost of up to 3.8ghz when i need it.
Btw MemoryHouse.com has the Mushkin Ascent memory at 158.74 heres a link use price match.
Buy Mushkin Ascent PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 240PIN Dual Channel Memory Kit
Save yerself 10 bucks on the ram and get the Asus P5Q-E from the difference.
Asus P5Q-E - It is only $162.76 so only 5 bucks more use pricematch again on ncix for this.
Buy ASUS P5Q-E ATX LGA775 P45 DDR2 3PCI-E16 2PCI-E1 2PCI SATA2 Sound GBLAN eSATA 1394 Motherboard
Dashock
Toronto
I think thats why i guess the Op wanted to save money with a powersupply as part of a combo with the case please correct me if im wrong thats the only reason i can see.
