Finally Built!!!
Sameer
Active member
Hey guys... I just wanted to thank all of you for helping me build my new PC and what a PC it turned out to be. I will post the final specs for you guys. Won't let me post pics :(
CPU: INTEL Conroe E6700 2.67GHz FSB1066MHz 4MB LGA775 Dual-Core (BX80557E6700)
MB: EVGA 122-CK-NF68-A1 LGA 775 NVIDIA NFORCE 680I SLI ATX INTEL (122-CK-NF68-A1)
RAM: OCZ 2GB (2x 1GB) DDR2 PC2-6400 Platinum Revision 2 Dual Channel (OCZ2P800R22GK)
VID: EVGA 768-P2-N831-AR GEFORCE 8800GTX 768MB DDR3 575MHz DVI DVI HDTV (768-P2-N831-AR)
HD: 2 WD Raptor 150s in raid 0 - Western Digital Raptor 150GB 1.5Gb/s 10000rpm 16MB (Raptor 150GB)
PSU: ThermalTake TOUGHPOWER 750W ATX 12V 2.2/14CM (Modular)
CASE: Silverstone TJ09 Black w/ side window
Cooler: Thermalright 120 Ultra Extreme
KB: Logitech G15 Gaming Keyboard - USB (G15 Gaming KB)
Mouse: Logitech MX518 Gaming-Grade Optical Mouse 8 buttons wired USB (MX518)
DVD: Asus 18x DVD-RW Drive Black SATA Lightscribe (DRW-1814BLT)
Mon: 2 x Dell FPW2704 Rev A04
Thanks again,
Sameer
Babrbarossa
New Brunswick
Man, That's a beauty! Let us know what kind of overclock you get out of it. I'll bet you could break 4GHz if you found a nice cool place to run it.
To post pics, you can either use our image hosting, or just click the paper clip symbol when composing the message.
Sameer
Active member
Got it... They were too high res before. :)
Sameer
Active member
So far I've gotten 3.7GHz, but I'm really tired and I'll try for 4GHz and over (hopefully) tomorrow. I'll let you know how it goes and I'll also have more time now to browse the forums :)
Deathspawner
New Brunswick
That system is superb, you made some great choices. After seeing that TJ09, I almost want to get one. The clearance on your 8800GTX is nice... on my P182, I had to remove the HDD trays in order to fit my card in.
Question on the monitors. When you game, do you spread it across both or just play it on one? How is it playing a game on a angle like that? I do something similar, but I just turn my keyboard and mouse on the same angle.
Great setup :thumb:
Sameer
Active member
Thanks a lot Deathspawner!
The case is amazing and I had absolutely no issues with things being too big, in fact, some of the cables were too short and had to be lengthened :(
Belive it or not, I haven't really had a chance to game much on my new rig. I'm still using my old rig and I just have the games on one monitor for now. I will install more on my new rig soon and keep you updated :)
Patriote
New-Brunswick
Nice build Sameer!
I like the dual monitor set-up. I wonder what kind of gaming experience you get when playing with 2 monitor. Probably too large for my taste but i never tired it so...lol
Let the overclocking begins!
