Firegl x2 AGP 4x/8x on Tyan thunder K7 don't work
maytagazn
Member
Me again!
another problem
I've got a Tyan Thunder K7 which has a AGP Pro 50 4x slot. I want to put my FireGL x2 256t into this thing but i get a blank screen and a "no signal" on my monitor.
I've been readin up on the spec (and reading anyting that pertains to tyan k7 and firegl x2) and i can 't find a clue as to why it won't work.
The Tyan k7 has a "Universal AGP Pro 50 4x" slot that should accept cards with both a 3.3v and a 1.5v notch (AGP 2x/4x). My FireGl x2 only has a 1.5v slot and it is a 8x agp card with compatability with 4x slot (i used to use it with my dual P3 933 with no problem so i know its compatable with agp 4x)
Right now im using a Nvidia 6600gt 256 on my Tyan k7 without a problem. The 6600gt also is an 8x card with a 4x compatablility; however, this card has a 3.3v notch AND a 1.5v notch while my Firegl only has a 1.5v notch.
Both the 6600 and the FireGL are NOT AGP pro and they don't have to be to work in an AGP Pro 50 slot. And both these cards have an extra power jack that needs to be hooked up to the power supply.
It puzzzles. I"ve tried and tried the FireGL just won't work!
I hate computer
This is frustrating
I would like to use the FireGL on my machine
Vancouver Canucks will emerge as the victor in the playoffs
thanks
SKYMTL
HardwareCanuck Review Editor
Montreal
If you are going from the 6600 to the FireGL you will DEFINATELY want to wipe the HD and reinstall the drivers.
In the past I have had nothing but pain when switching between Quadros and FireGL cards.
maytagazn
Member
I know what you mean. i've also had that experience.
however, the problem remains...the firegl when installed onto my Tyan k7 wont show anything on the monitor. The system originally came with an Nvidia Quadro4 which is quite out dated.
Right now the FireGl is running in my A 64 3200+ system (with an agp 8x slot). I would like to do a swap. 6600gt in and A 64 system and the Firegl in the Dual AMP 2200 due to the fact that i do most of my modeling on the Dual AMP. And i usually render on theh A 64
