thorn
All the excitement of recent hardware releases (despite lack of availability) and the fact my rig is starting to show it's age (25-30 fps in Cyberpunk, struggles in BL3 as well), got me itching to build a new rig.
The Basics:
Budget - 2250 CAD before taxes
Location - Canada (Montreal area)
Use - Largely gaming. With the lockdown I have done a little streaming. I also occasionally dabble in photo/video editing. However it remains that gaming will be the main purpose and I play a variety of genres (RPG, shooters, RTS/TBS, platformers, etc..). While I certainly no longer have the time to play as much as I have in the past, when I do I want to be able to really enjoy it and be able to turn up the settings/eye candy.
Also, I find myself keeping my rigs longer than before. Current one I have had for 5 years and would target something similar with whatever I build next.
Resolution - Earlier this year I bought a 34" Ultrawide (2560*1080). I had been skeptical for so long about them, but really enjoying it. Great for both gaming and productivity. I will likely have this for a while, but can see myself maybe going up to 3440x1440 prior to next upgrade.
Timeline - honestly I'm in no hurry, in my mind it will happen this year but depending on some other things going on it may get pushed into next year.
Overclocking - initially no. Perhaps some further down the line if it helps squeeze more time out of the rig.
Theme/"bling" - I am looking to go black and white, though depending on what I reuse this might need to be tweaked
. Also, I want to minimize the RGB as much as possible.
The Build:
Very high level I'm looking at building around a Ryzen 5 5600X (haven't gone AMD since the early 2000's) and an RTX 3080 (my last team green card was a 7800 GT...). However as you'll read below I am open to suggestions.
The Breakdown (and possible hardware reuse):
CPU: As mentioned above I am looking at going with a Ryzen 5 5600X. If AMD releases a 5600 and price/perf is better without giving up too much perf I would probably go with that.
Mobo: Unless there are particular brands/models I should avoid I don't really have any special requirements here. Well, aside from possible colour scheme.
GPU: As mentioned above I am looking at going RTX 3080 for two main reasons 1- DLSS, now I know AMD is going to come out with their equivalent, but don't yet know how that will perform and 2- Ray tracing. nVidia is doing a better job here and I figure at my resolution of choice I can use it and still get decent frames. Now obviously with rumours/possible 3070 TI and 3080 TI and whatever AMD may come out with, and availability, things may change.
PSU: I have been running a Mushkin Joule 1000W for 10 years now (2 builds), I think it may be time to retire this puppy. I am leaning fully modular and probably a 750W 80+ gold
RAM: Here is the first of my reuse questions. Currently I have a set of 16GB (2 x 8) Corsair Vengeance LPX DDR4-2400 CL14 (XMP 14-16-16-31-47) and it is a dual rank kit. Doing a little research running "slower" memory but with good timings and upping the infinity fabric frequency can get you similar performance to 3200 or 3600mhz kits. Not sure how many have actually tried this, would definitely appreciate input on this.
Case: I have been looking at the be quiet! Pure Base 500DX and LANCOOL II Mesh (the white versions). However I am debating if I should reuse my Corsair Obsidian 800D (of some fame - it is the one of a kind Hardware Canucks custom case! https://hardwarecanucks.com/forum/threads/hardware-canucks-custom-case-by-mnpctech.28135/). My concern is the airflow and well the case is 10 yo and so are the fans which I would need to replace. It is also a massive case, which is why I am looking more at a mid-tower. I have upgrade the hotswap bays to SATA3 and have the kit to add USB 3 to the front panel but no usb 3.1/3.2 or usb C on the front. It's still a beaut though, however it could probably use a little TLC (a real dust magnet)
Cooling: I have reused the water cooling loop that was part of the original build:
Storage: I am going to reuse what I have now (Samsung 850 PRO 128gb for OS, Samsung 860 EVO 1TB for games and a 2TB WD Black HDD for storage). I'll upgrade as I need
Peripherals: Same story as storage
I think I have covered everything. I look forward to any feedback, comment, suggestions and sorry for the wall of text
The Basics:
The Build:
- EK Supreme HF White CPU Block
- Limited Edition FrozenQ Fusion Res
- EK DCP Pump (died on me so I replaced it with a Laing DDC 3.1 Quiet 10W Pump ( MCP350, DDC-T1 ) and EK-XTOP DDC)
- Black Ice SR1 420MM Radiator
