First build
cards2121
New member
Hi I am lookiong for advice for building a new gaming PC. I play everquest and Battlefield Bad Company 2 mostly. I am looking to spend $1100-$1300 with no monitor.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing. Gaming
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread $1100-$1300
3. What country YOU will be buying YOUR parts from. US newegg.ca
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture. Intel
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. Monitor will be reused
7. IF YOU plan on overclocking or run the system at default speeds. OC
8. WHEN do you plan to build it? soon
9. What resolution do you use? 1680x1050
Antec Nine Hundred Black Computer Case $99.95
Intel BOXDP45SG ATX Intel Motherboard $129.99
Intel Core 2 Quad Q9550 2.83GHz LGA 775 95W Quad-Core Desktop Processor $278.99
EVGA GeForce GTX 470 (Fermi) SuperClocked 012-P3-1472-AR Video Card $359.99
Seagate Barracuda 7200.12 750GB 3.5" SATA 3.0Gb/s $69.99
CORSAIR CMPSU-750TX 750W Compatible with Core i7 Power Supply $109.99
Sony Optiarc DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B $26.99
CORSAIR XMS3 DHX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) $119.99
Looking for sugestions on CPU cooling
Grand Total:$1,215.88
Shipping:$15.80
martin_metal_88
Quebec City
I would go for a P7P55D for mobo and I5 750. It's about the same price that the 9550 and will perform way better. You will also be in new gen CPU which is better in long term upgrade.
For the cooler, if you want light OC then a Coolermaster Hyper 212 + is like 30 box and will do just fine. If you want harder oc then go with the Prolimatech Megahalem with Scythe Gentle Typhoon 1450 RPM. I isted all the product under. You can alsop find a WAY BETTER case for the same price. CM 690 II or CM HAF 922. You will see that the 470 will be DEAD FIT in a nine undred so you won't be abble to use 3 of the HDD slot. the 2 case I listed have side mounted HD so you have an extra 1-2 inch IN the case and you can use all your HD with big card. For the rest it's all ok IMO.
Newegg.ca - COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler
Newegg.ca - Scythe GentleTyphoon D1225C12B4AP-14 120mm Case Fan
Newegg.ca - Prolimatech Megahalems Rev.B CPU Cooler
Newegg.ca - Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
Newegg.ca - ASUS P7P55D-E LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Newegg.ca - COOLER MASTER CM690 II Advanced Black Steel body / Plastic + Mesh bezel ATX Mid Tower Computer Case
Newegg.ca - COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
cards2121
New member
modification
Thanks for the feed back Martin_metal_88. I looked at the HAF 922 case and it like it as well as the cool master Hyper 212 CPU cooling. Would i be better off going up to the I7 processor or is it overkill for what I am doing? if so what do you think about this set up?
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM $26.99
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case $89.98
Seagate Barracuda 7200.12 ST3750528AS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $69.99
EVGA 012-P3-1472-AR GeForce GTX 470 (Fermi) SuperClocked 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ... $379.99
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... $109.99
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C7 $134.99
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $229.99
Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor Model BX80601930 $288.99
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long ... $44.99
Grand Total: $1,364.61
ZZLEE
KANATA
The i7 rocks
I have a i7 920 it will out preform any 775 chip with its 4 cores and 8 threads if you use windows 64 bit operating system. I like windows 7 (64 bit) if you go the i7 rout its the OS fore you :biggrin:
Edit: if you go i7 go fore 6 GB of ram fore tripple channel. or 3 1 GB dimms fore tripple channel. Tripple channel memory also.
martin_metal_88
Quebec City
I would go with this one but you are using 4 GB ( 2 X 2 ) in a computer that need 3 or 6 stick.
This is the kind of memory you need.
NCIX.com - Buy Corsair XMS3 TR3X6G1333C7 6GB DDR3 3X2GB DDR3-1333 CL 7-7-7-20 1T Core i7 Memory Kit - TR3X6G1333C7 In Canada.
NCIX.com - Buy G.SKILL F3-12800CL9T-6GBNQ 6GB DDR3 3X2GB DDR3-1600 CL 9-9-9-24 Triple Channel Memory Kit - F3-12800CL9T-6GBNQ In Canada.
I prefer the G.skill over the corsair.
rapmaster
Brossard, QC
If you're gaming most of the time, i5 750 or Phenom II make more sense. It cost less while it has mostly the same performance in gaming. Also, less heat and consume less power too.
jcmaz
Vancouver, BC
The choice of cases are subjective but there are many other choices than the ancient Antec 900.
I would pick: Coolermaster 690II Basic, Azza 910 Helios or Solano, NZXT Beta Evo/M59 etc...
